How to compute WENO-reconstructed flux in local characteristic field? |
August 20, 2017, 04:02 |
Oleg Sutyrin
Rep Power: 10 |
I'm trying to apply finite-difference characteristic-wise WENO method to 1D Euler equations:
Physical values are set at grid points , so we need to approximate fluxes at mid-points : where are sought-for approximation of physical fluxes . My algorithm is the following: 1) For each , we calculate simple average state and, using it, local eigenvalues , right eigenvector matrix and it's left counterpart . (Subscript will be omitted below) 2) Now we transform , its differences and flux differences to local characteristic field: It is done only for relevant grid points which in my case () are . 3) Then we reconstruct characteristic variable values by WENO method using , and . We get two "candidates": where are a convex combinations of corresponding polynomial functions obtained by WENO method. The next step would be to compute 2-point flux function using these reconstructed values. I'm using Lax-Friedrich's function: where is maximum value of eigenvalue (different for each of equations, since they are decoupled now). But how to compute these and using ? In component-wise approach it is simple: we reconstruct base values - , for example - and the use explicit formulas to compute and , but we don't have such formulas for because is expressed in local characteristic field... |
August 22, 2017, 06:03 |
Oleg Sutyrin
Rep Power: 10 |
It seems that I was misunderstanding how the flux is reconstructed:
My idea was to reconstruct base values - (or if we are performing characteristic decomposition) - and then substitute them to formulas of (or ) to obtain reconstructed fluxes. It looks like the correct way is to apply reconstruction procedure to (or which is obtained by transformation ) itself. Some quick tests I performed with this approach show very plausible results. |
September 4, 2017, 14:24 |
Rep Power: 11 |
Hi there,
Here's what I am doing: after reconstructing the characteristic variables at the face, I use the left eigenvector matrix to convert them back to primitive variables. Then, I use these to compute the flux using the flux function, e.g. Lax-Friedrich method. It has performed well in several 1D test cases. USV |
charateristic-wise, finite-difference, weno |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
