Moving Boundary vs Mesh Translation - Flow past a Cylinder |
August 14, 2017, 20:38 |
A E
Rep Power: 11 |
I am working on simulation of flow past a cylinder when cylinder is under a forced oscillation. I have a question regarding this case and would like to know your opinions. To simulate the cylinder oscillation, in order to preserve the mesh quality, I implement the motion to the entire flow domain. This means that the whole domain is oscillating with a velocity field resembles the original cylinder motion. Do you guys think I need to consider any extra terms when calculating the lift force? Currently, I am just integrating the pressure on the cylinder to calculate the lift, but I thought I might miss some other unseen forces due to simplifying the problem. Thanks, A E |
flow past cylinder, forced vibrations, mesh translation, moving boundaries, star ccm+ |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
