getting low value of Strouhal number-flow around cylinder
Old   August 3, 2017, 00:26
Default getting low value of Strouhal number-flow around cylinder
N B Khan
bestniaz is on a distinguished road
Dear Friends,
In case of flow around cylinder at Reynolds number Re=3900 (D=0.1m and Velocity=0.6) and domain is 3 dimensional. I am using ANSYS Fluent with LES model.
I am getting good value of drag coefficient, recirculation length and angle of separation. The only concern is value of Strouhal number. Using FFT in ANSYS Fluent, I am getting St=0.14 which not agree with experimental and other numerical studies (St=0.21). If I calculate manually Strouhal number, still the result is St=0.14.
I am using correct value of reference value due to which drag coefficient value is correct. At Reference option, I used the following value
Length=0.1
Area= 0.04 (bcz length of cylinder is 4D)
Can anyone suggest, why this error happen?
Regards,
Niaz
bestniaz is offline   Reply With Quote
flow around cylinder, large eddy simulation., reynolds number
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
