July 28, 2017, 07:30 |
Calculation of spectral transfer flux T(k)
Gareth
Rep Power: 16 |
Hi guys,
I would like to get your advice on this. In homogeneous turbulence, a dynamic equation can be written for the 3D energy spectrum E(k), whereby the time rate of Energy spectrum is related to the spectral energy transfer T(k) and dissipation: dE(k)/dt = T(k) - 2vk^2E(k) Now, I have calculated E(k) from a 3D data field, and would like to calculate T(k). Is there a direct way to work out T(k)? I have tried to take the Fourier transform of the non-linear triad interactions in physical space, but have not achieved a good result. Appreciate your help! |
July 28, 2017, 12:53 |
Filippo Maria Denaro
Rep Power: 73 |
Without more details I cannot say if you are wrong in the procedure...What is the problem you see? Does the integral of T(k) vanish?
August 1, 2017, 05:20 |
Gareth
Rep Power: 16 |
The T(k) profile seems to be very noisy. Just to make sure that I am on the right track.. I computed the product u_i*u_j*d(u_i)/dx_j, and then take the Fourier transform of it and obtain the real coefficients.
August 1, 2017, 13:51 |
Rep Power: 73 |
Try to check the expression reported in the book Turbulence of U.Frisch, from sec.6.2.2 it explains the transfer function for homogeneous turbulence
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Problem with mass flux calculation in libsimpleFunctionObjects.so | BlnPhoenix | OpenFOAM Running, Solving & CFD | 1 | June 24, 2017 16:36 |
mixed boundary conditions including heat flux, convective heat transfer and radiation | lotus_blue | FLUENT | 0 | April 3, 2013 19:55 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
Heat Transfer Coeff. at Heat Flux Boundary | Rushyen | CFX | 6 | January 18, 2001 06:09 |
