CFD Analysis: Vortex in 2 Perpendicular Plates
Old   July 22, 2017, 11:54
Default CFD Analysis: Vortex in 2 Perpendicular Plates
piralis's Avatar
Vaggelis Piralis
piralis is on a distinguished road
Hi my name is Ben
I want to simulate a Laminar_Flow(0.001m/s)
over a Horizontal_Plate (5 cm) that falls in front of a Vertical_Plate(30cm)!!
I want to study Vortices that generate in the spot , where the 2 Plates are forming 90° degrees .
(see the photo attached)
I run the calculation as laminar_flow and normal_square_ mesh (400*2400) but the results dont show the Vortices I want to see in the Spot (Path_lines , stream_lines , velocity_vector)
I will appreciate any help if you know something because I am really stuck
Thank you Community
Sent from my MI 5 using CFD Online Forum mobile app
piralis is offline   Reply With Quote
Old   July 22, 2017, 12:05
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
You should provide much more details about the formulation and numerical setting you are using. Then, post your solutions
FMDenaro is offline   Reply With Quote
CFD Analysis for parking area kendelv0xx CFD Freelancers 2 August 2, 2013 08:58
confusion regarding geometry for CFD analysis jeph91 Main CFD Forum 2 June 22, 2013 17:33
How do you do a fluent CFD analysis for a boat? UHMStudent FLUENT 2 July 24, 2011 13:45
CFD software capable of modal analysis? Jim-gineer Main CFD Forum 4 January 14, 2010 10:29
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 11:51
