July 13, 2017, 15:18 |
#21 | |
dilaw meda
Rep Power: 9 |
If there is no solution, i think i will just do a dynamic study, because it is impossible for me experimentaly to get température mesurements in a constant time step, because i dont know if in that moment the velocity will be stable on the device's screen. Sent from my F1f using CFD Online Forum mobile app |
July 13, 2017, 16:48 |
#22 | |
dilaw meda
Rep Power: 9 |
For the preconditioning, what i understand is that it has un effect of reducing the acoustic speed of the system to accelerate the convergence in incompressible flows as the mach number goes to zero wright? But i dont know how to put that in the software Sent from my F1f using CFD Online Forum mobile app |
July 13, 2017, 16:55 |
#23 | |
Filippo Maria Denaro
Rep Power: 73 |
http://www.afs.enea.it/project/neptu...th/node378.htm but you can use also the NITA |
July 13, 2017, 17:09 |
#24 | |
dilaw meda
Rep Power: 9 |
July 13, 2017, 17:29 |
#25 | |
dilaw meda
Rep Power: 9 |
July 13, 2017, 17:36 |
#26 | |
Rep Power: 73 |
Have you infos about a physical initial condition? Otherwise, if you set an arbitrary initial condition you have to wait enough time to let the solution correlating in a physical way from the arbitrary numerical one. |
July 13, 2017, 17:50 |
#27 | |
dilaw meda
Rep Power: 9 |
July 13, 2017, 18:17 |
#28 |
dilaw meda
Rep Power: 9 |
July 13, 2017, 22:16 |
#29 | |
Arjun
Rep Power: 34 |
This must be NITA of fluent. It is its main problem. |
July 14, 2017, 03:56 |
#30 | |
Rep Power: 73 |
Does it appear after the first time step or during the transient? It could be to an error in the setting of the BC.s or a numerical instability ... |
July 14, 2017, 04:00 |
#31 |
Rep Power: 73 |
Are you setting the fractional step or the PISO? Did you set a second order time-advancing?
July 14, 2017, 11:44 |
#32 | |
dilaw meda
Rep Power: 9 |
July 14, 2017, 11:51 |
#33 | |
dilaw meda
Rep Power: 9 |
July 14, 2017, 12:24 |
#34 |
dilaw meda
Rep Power: 9 |
- i used hybrid initialization , a warning displays
Warning: convergence tolerance of 1.000000e-06 not reached during Hybrid Initialization. -i started calculation nb : there is also warnings from the begining of the calculation: reversed flow in 4884 faces on pressure-outlet 6. reversed flow in 4884 faces on pressure-outlet 7. - after incrementing to the 3rd time step : # Divergence detected in AMG for x-momentum: protective actions enabled! # Divergence detected in AMG for x-momentum, temporarily solve with BCGSTAB! Error: Divergence detected in AMG solver: x-momentum Error Object: #f |
July 14, 2017, 13:03 |
#35 |
Arjun
Rep Power: 34 |
my advise is that run first few time steps with implicit method without worry about cost.
This is reason, FVUS have a setting that says fraactional solver after this many time steps. In the start it is not converged and NITA has problems. |
July 14, 2017, 13:35 |
#36 | |
dilaw meda
Rep Power: 9 |
July 14, 2017, 13:49 |
#37 |
Rep Power: 73 |
Check your BC.s, maybe they do not satisfy the incompressibility constraint
July 14, 2017, 13:51 |
#38 | |
dilaw meda
Rep Power: 9 |
The roof is wall, nozzles wall also, and the rest i set it pressure outlet because i wanted to limite the domaine, should i put the real dimensions of the room and set every thing as wall ? Sent from my F1f using CFD Online Forum mobile app |
July 14, 2017, 13:56 |
#39 | |
Rep Power: 73 |
Pressure outlet must allow the mass flow rate entering from the nozzles to exit. If that does not happen, the continuity equation is not satisfied, the mass increases and the error in the divergence-free constraint acts as a source driving to divergence. |
July 14, 2017, 14:07 |
#40 | |
dilaw meda
Rep Power: 9 |
A question, could the temperature of the jet in my case have an influence in compressibility ? Sent from my F1f using CFD Online Forum mobile app |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
Monitoring Residuals - Initial or Final? | BigPapi34 | OpenFOAM Running, Solving & CFD | 1 | November 3, 2014 06:31 |
Monitoring Residuals - Initial or Final? | BigPapi34 | Main CFD Forum | 0 | November 3, 2014 06:23 |
Monitoring residuals in Workbench-Fluent using Remote Solver | fadiga | Main CFD Forum | 2 | October 16, 2013 16:43 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 13:18 |
