David
Rep Power: 10 ![]() |
Dear all,
I have a fully coupled unsteady FEM Navier-Stokes code, used in the context of hemodynamics, in particular flow through stenosis with Reynolds numbers of the order of ~2500. (I suspect the flow to be near transition; LES will be carried out later to confirm.) I'd like to implement projection/fractional step/splitting methods for efficiency. There are many schemes and many names in the game, so I'd like to ask about your experiences and recommendations. What are your favorites? In particular: implicit or explicit convection? Pressure treatment? Thanks for your advice! Regards David |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
I always used the pressure-free projection method... Second order in time using explicit for the convection and the SGS terms and implicit for the diffusion.
David
Thanks for your comment. Can you elaborate on why you chose pressure-free (e.g. instead of incremental pressure correction)?
Are there any considerations w.r.t. BDF2 vs. Crank-Nicolson? Thanks |
#4 | |
In general, when well-formulated, these fractional methods are all quite good. A detailed analysis of each method does not lead to a definition of the "best one". I can say that each method produces a different meaning of the "pressure" field. Then, BDF2 vs. Crank-Nicolson is something related only to the solution of the intermediate momentum equation. The CN scheme produces a stable solution and allows to work with reasonable time-step. The intermediate velocity must be prescribed at the boundary and this is, however, an issue to consider carefully. The BDF2 I used (Adams-Bashforth) is stable provided that the time-step is constrained by the (cfl-Re_h) stability region. You can find a lot of published literature about that. |
fem, fractional step, projection method |
How to use PIMPLE properly? | floquation | OpenFOAM Running, Solving & CFD | 27 | August 12, 2024 10:15 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
