No spurious currents in Level Set Multiphase Method?
Old   June 15, 2017, 17:09
Default No spurious currents in Level Set Multiphase Method?
Lieh
akesm is on a distinguished road
The reasons for spurious currents in the conventional algebraic volume of fluid is known to us, and we are familiar with the attempts that have been made to decrease them in the community.
The question is that why such spurious currents are not observed when using Level Set method (Or at least it is known that Level Set outperforms in terms of not inducing spurious parasitic velocities close to the interface).
Because to me, all processes are similar to VOF (i.e. solving an advection equation, the way normal vector and curvature are calculated, and the way the surface tension force is used in the momentum balance equation) except that all are based on a distance function other than volume of fluid fraction.
So if spurious currents are attributed to an imbalance between surface tension force and pressure force caused due to inaccuracies in curvature approximation and discretization of the surface tension force in the momentum equation, to me there is no reason that same thing does not occur for the level set method.
akesm is offline   Reply With Quote
Old   June 19, 2017, 06:24
akidess's Avatar
Anton Kidess
1. Level set method does suffer from spurious currents too.
2. It outperforms basic VoF in this regard because curvature calculation is less noisy.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
level set method, parasitic velocities, vof method
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
level set method for simulating detonation Amir Main CFD Forum 4 July 31, 2008 16:13
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
level set method with TVD scheme? zhanglei Main CFD Forum 1 April 25, 2000 15:01
