May 31, 2017, 01:52 |
RANS simulation using SST Menter's model
Prakash
Rep Power: 11 |
Hi all,
I have been trying to validate a zero pressure gradient flat plate case using SST menter's model. The link to the problem I am trying to validate is https://turbmodels.larc.nasa.gov/flatplate.html As you can see from the link, there is a symmetry and a adiabatic wall condition. My solution is blowing in the transition region between the symmetry and no slip boundary condition(adiabatic wall condition). I am using a finite volume scheme with the flux at the interface reconstructed using symmetric average of functional values + its gradients respectively(Basically the avg of Taylor's series at points i and i+1 with 2nd order truncation error). The grid resolution is 69x49 and clustering is done in the region of boundary layer and leading edge. It is done similar to one which is there in this link https://turbmodels.larc.nasa.gov/flatplate_grids.html |
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 14:57 |
Why Menter's SST model low-Re issue has not been seriously investigated? | vkrastev | OpenFOAM | 58 | January 8, 2018 16:20 |
Using radiation model for simulation of flat plate solar collector | marjanbn | FLUENT | 1 | February 24, 2017 18:22 |
problem with SST k-omega model | avi031 | FLUENT | 5 | January 29, 2012 18:24 |
CFX-11 vs CFX-13 SST Model | Zigainer | CFX | 10 | December 2, 2011 05:40 |
