Open-source inverse design code for cascades
Old   May 18, 2017, 05:04
Question Open-source inverse design code for cascades
HenrikSmutje is on a distinguished road
Hi all,
I'm currently looking for an open-source code for the inverse design of a turbine cascade. I only need a simple panel method that can give me a quick estimate of Cp etc. to get a first design of the blades. For more precise NS simulations in the later design process I got the tools.
So far I only came across Xfoil and JavaFoil which work well for single airfoils but not for cascades. So technically I only need an equivalent which allows for periodic boundary conditions.
The only tools I found so far are MISES or CASCADExpert which, unfortunately, are only commercially available. So any hint for similar codes that are available open-source or at least as freeware would be much appreciated. Thanks!
HenrikSmutje is offline   Reply With Quote
cascade, inverse design, opensource, panel method
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
