Mass transport simulation
Old   May 17, 2017, 10:24
Post Mass transport simulation
abi
abi111 is on a distinguished road
Hi
Would appreciate some help with mass transport issue.
I would like to perform a 2D density driven flow simulation (haven't decided on the CFD platform yet). The system involves a fully miscible, less dense then water, solution which sits on top of water. The miscible solution diffuses into the water (i assume thermodynamic equlibrium which means that the dissolution rate is governed by diffusion) causing the water under the interface to become denser thus forming an unstable condition followed by natural convection. I'm trying to define the boundary condition at the interface (assuming its location is fixed) but i cannot define it as a species that is dissolved in water because it is still "pure".
Any ideas?
Thanks!
abi111 is offline   Reply With Quote
Old   May 18, 2017, 05:07
Arjun
arjun will become famous soon enougharjun will become famous soon enough
which software we are talking about?
arjun is offline   Reply With Quote
Old   May 18, 2017, 09:40
abi
It is likely i will use comsol for this
Old   May 18, 2017, 11:32
Arjun
I don't know much about comsol but in fluent starccm etc you can patch the value to a region as initialization. Off course then you would have to make two regions, one for one fluid another for another fluid.
In FVUS/Wildkatze , I provide patching in a box or sphere because of this, so there you can use your mesh the way it is, just create a box patch where the values will be fixed to what you want.
For example here , the column of water is from patching in a box and mesh is single region mesh
https://www.youtube.com/watch?v=dGMN_OeuO24
density driven flow, mass transport, miscible fluids
[Other] Multi species mass transport library [update] novyno OpenFOAM Community Contributions 111 November 10, 2021 00:37
mass imbalance in Transient simulation sina_mech FLUENT 3 May 1, 2018 06:26
problems concerning mass conservativity in bubbleFoam with custom scalar transport cutter OpenFOAM Programming & Development 3 February 10, 2015 05:25
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
