what length scale should be used when calculating kolmogorov scale of fountain flow?
Old   May 9, 2017, 01:22
Default what length scale should be used when calculating kolmogorov scale of fountain flow?
John-Lee is on a distinguished road
I want to use the LES and Laminar model in Fluent to simulate a fountain flow as shown in the attachment. So a fine mesh is needed. The Kolmogorov scale can be estimated by L (length scale) and Re (Reynolds number). My question is what is the length scale I should use when calculating Kolmogorov scale of the fountain flow?
John-Lee is offline   Reply With Quote
Old   May 9, 2017, 03:16
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Do you want to compare LES to a laminar (no-model) solution?
The Kolmogorov lenght scale depends on the physical viscosity and dissipation http://www.eng.utah.edu/~mcmurtry/Turbulence/turblt.pdf
FMDenaro is offline   Reply With Quote
fountain, kolmogorov scale
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
Modelled Length Scale in SAS-SST Simulation jego Main CFD Forum 0 January 16, 2016 07:45
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 19:11
Interface treatment in turbulent model and its length scale. paka OpenFOAM Running, Solving & CFD 0 February 15, 2014 03:02
Integral Length Scale vs Turbulent Length Scale Scott Nordsen FLUENT 2 January 20, 2014 02:17
