Khaled Ahmad
Rep Power: 10 ![]() |
I am working on 2D turbulent, isothermal, non-reactive single phase flow in general domains solver. I need to verify it by solving some experimental cases.
Would you please suggest for me some cases in that specific area ? May be a valve, some pipe with obstacles it should be EXPERIMENTAL, I think Thanks |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
Have a look to the experimental simulations described here
http://torroja.dmt.upm.es/turbdata/a...ARD-AR-345.pdf http://www.dtic.mil/dtic/tr/fulltext/u2/a286061.pdf |
2dimensional, axisymmetric, cases, experimental, solver |
MRFSimpleFoam wind turbine case continuity error | ysh1227 | OpenFOAM Running, Solving & CFD | 1 | August 16, 2016 09:25 |
Simple channel case using cyclicAMI will not converge | cbcoutinho | OpenFOAM Running, Solving & CFD | 3 | August 4, 2015 12:28 |
Cavity tutorial case | shinde.gopal | OpenFOAM Running, Solving & CFD | 3 | June 12, 2015 05:50 |
MRFSimpleFoam wind turbine case diverges | ysh1227 | OpenFOAM Running, Solving & CFD | 2 | May 7, 2015 10:13 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
