ESI-CFD Problem with initialization from previous solution |
April 25, 2017, 16:36 |
Anil Kumar
Rep Power: 10 |
I have a converged solution for a geometry and have mapped the dtf file to a new geometry (almost same with a bit extension of length but same number of cells and zones). CFD- toolkit showed mapping of zones successful. Now, if I open the new file in CFD-view, it is showing the converged solution data with a bit of distortion (likely due to change in geometry) but if i try to run the new dtf file in fastran with initial condition as previous solution its prompting that no previous solution is found. Can someone help me solve this problem? |
esi-cfd |
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli | mmkkeshavarzi | FLUENT | 1 | June 28, 2024 07:03 |
Initializing an unsteady solution from previous solution | Mahdi_Kh | FLUENT | 0 | May 31, 2016 08:12 |
Access violation error during solution initialization | kuldeepnitb@gmail.com | FLUENT | 0 | January 14, 2016 23:07 |
knowledge about CFD. | VASANT NAVATI | CFX | 1 | November 28, 1999 00:22 |
CFD - Trends and Perspectives | Jonas Larsson | Main CFD Forum | 16 | August 7, 1998 16:27 |
