Why is the freestream sensitivity of the k-omega model a handicap? |
Ovid
Rep Power: 9 ![]() |
Hello to all,
Why is the freestream sensitivity of the k-omega model a handicap? I have that question after reading the book of Wilcox "Turbulence modeling for CFD" and after thinking about its comments on the behavior of the standard k-omega when the flow is in the transitional regime. It is noted that this sensitivity is beneficial for capturing the dependence of transition on flow free stream turbulence. Mismatches are welcome! ![]() Thanks for reading, Fole. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Wilcox devotes a lot of attention to this topic in his book.
To be more specific, the k-omega model is sensitive to the freestream boundary condition for omega. The problem is more-or-less self stated. The solution depends on what you specify as the freestream boundary condition for omega. This means the k-omega model is a somewhat failure as a model because it depends on the user input! I.e. for each individual problem, you must determine beforehand the correct freestream value for omega, which means you cannot apply the k-omega model to new problems, you can only apply it to problems in which you already know the solution, which is not what a model is for. |
freestream, k-omega |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
coalChemistryFoam: "Foam::error::printStack(Foam::Ostream&) at ??:?" | musabai | OpenFOAM Running, Solving & CFD | 2 | February 20, 2015 14:07 |
Is it possible to model natural convection in a 2D horizontal model in fluent | caitoc | FLUENT | 1 | May 5, 2014 13:32 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
k-e model and mesh sensitivity | raj calay | Main CFD Forum | 13 | July 28, 1999 15:48 |
