Viewing the 3D plot in matlab
Old   April 10, 2017, 07:37
Default Viewing the 3D plot in matlab
Karan Gupta
KaranG is on a distinguished road
Dear members
I am using an open source code COULWAVE to run the wave propagation in a wave flume around a conical island.
In the first case I used the Solitary wave and used the MATLAB code to get the 3D plot and it is shown below.
In the second case I used the Sinosidal wave for the same conical island as in the first cased and used the same MATLAB code to get the 3D plot but this time in the 3D plot the conical island is not distinctly visible. It is shown below.
I am unable to understand the reason for the same.
Please help me out.
your sincerely
Karan Gupta
The MATLAB code used for plotting is given below.
clear all
clf
load time.dat
nt=length(time);
if nt==0
nt=10000;
end
load s.dat
N_levels=s(2);
num_procs=s(3);
wave_map=zeros(63,3);
wave_map(1,=[0 0 .5625];
wave_map(64,=[1 1 1];
for i=2:63
for n=1:3
wave_map(i,n)=wave_map(1,n)+(i-1)*(wave_map(64,n)-wave_map(1,n))/63;
end
end
colormap(wave_map) % for blue / water-like surface
%colormap(jet)
for rank=0:num_procs-1
ind=['00' num2str(rank)];
file_ind=ind(length(ind)-2:length(ind));
eval(['load xloc' file_ind '.dat'])
eval(['load yloc' file_ind '.dat'])
filename=['dpth' file_ind '.dat'];
fid(5*rank+1)=fopen(filename, 'r');
filename=['zeta' file_ind '.dat'];
fid(5*rank+2)=fopen(filename, 'r'); % open the file
filename=['velo' file_ind '.dat'];
fid(5*rank+3)=fopen(filename, 'r'); % open the file
filename=['blvs' file_ind '.dat'];
fid(5*rank+4)=fopen(filename, 'r'); % open the file
filename=['vort' file_ind '.dat'];
fid(5*rank+5)=fopen(filename, 'r'); % open the file
end
% plot initial depth and determine glocal axis limits
clf
mx_x=0;
mn_x=1e6;
mx_y=0;
mn_y=1e6;
eval(['x=xloc' file_ind ';'])
eval(['y=yloc' file_ind ';'])
mx_x=max(mx_x,max(x));
mx_y=max(mx_y,max(y));
mn_x=min(mn_x,min(x));
mn_y=min(mn_y,min(y));
nx=length(x);
ny=length(y);
ho=zeros(nx,ny);
dum=fread(fid(5*rank+1),1,'int32');
ho(:,=fread(fid(5*rank+1),[nx,ny],'single');
surf(x,y,transpose(ho(:,))
view(20,150)
shading flat
hold on
end
colorbar
pause(.1)
% plot various surfaces
% mov =
% avifile('example.avi','FPS',41,'COMPRESSION','Cine pak','Quality',100); %
% to create movie inside matlab (Doesnt work that well)
for n=1:nt
clf
[n,nt]
nx=length(x);
ny=length(y);
zeta=zeros(nx,ny,N_levels);
tmp=zeros(nx,ny);
bl_hor_wall=zeros(nx,ny);
t_break=zeros(nx,ny);
h=zeros(nx,ny);
u=zeros(nx,ny,N_levels);
v=zeros(nx,ny,N_levels);
vort=zeros(nx,ny,N_levels);
us=zeros(nx,ny,N_levels);
vs=zeros(nx,ny,N_levels);
for s=1:N_levels
dum=fread(fid(5*rank+3),1,'int32');
u(:,:,s)=fread(fid(5*rank+3),[nx,ny],'single'); % read x-velocity array, at z_alpha
v(:,:,s)=fread(fid(5*rank+3),[nx,ny],'single'); % read y-velocity array, at z_alpha
dum=fread(fid(5*rank+2),1,'int32');
zeta(:,:,s)=fread(fid(5*rank+2),[nx,ny],'single'); % read free surface array
dum=fread(fid(5*rank+5),1,'int32');
vort(:,:,s)=fread(fid(5*rank+5),[nx,ny],'single'); % read surface vorticity array
us(:,:,s)=fread(fid(5*rank+5),[nx,ny],'single'); % read x-velocity array, at zeta
vs(:,:,s)=fread(fid(5*rank+5),[nx,ny],'single'); % read y-velocity array, at zeta
end
dum=fread(fid(5*rank+4),1,'int32');
bl_hor_wall=fread(fid(5*rank+4),[nx,ny],'int32'); % location of wet=0 and dry=99 cells
t_break=fread(fid(5*rank+4),[nx,ny],'single'); % breaking locations
h=fread(fid(5*rank+4),[nx,ny],'single'); % water depth, only different from h0 for landslide
hold on
surf(x,y,transpose(-h+max(max(abs(ho)))/100.),'CData',zeros(ny,nx,3)+.4,'EdgeAlpha',0.0,'B ackFaceLighting','reverselit')
surf(x,y,transpose(zeta(:,:,1).*(1-bl_hor_wall/99)-(bl_hor_wall/99).*h));
end
shading flat
axis equal
% axis([10 45 mn_y mx_y -10 10])
xlabel('x (m)')
ylabel('y (m)')
% % title(['Free Surface Elevation, Time (sec) = ', num2str(time(n))])
view(20,150)
% % zoom(2.7)
caxis([-.05 .5])
light
% axis off
% fname=['im' num2str(10000+n)]
% print('-djpeg100 ',fname)
pause(0.1)
end
fclose all;
KaranG is offline   Reply With Quote
Old   April 10, 2017, 08:02
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
why don't you first fix the same ranges ans scales?
FMDenaro is offline   Reply With Quote
Old   April 10, 2017, 08:55
Default Reply
Karan Gupta
Since there is no change in the code. The scales are apparently the same in both the cases. I have attached the code. Can you specify in which part of the code, the changes are suggested?
[OpenFOAM] Viewing a scatter plot of points overlayed on my paraFoam flow visualization karma15 ParaView 1 April 15, 2016 15:17
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 16:40
How to plot FLUENT contours on MATLAB Thiago Combustion FLUENT 1 October 10, 2013 15:13
Matlab PP: Generating X-vel Contour Error Plot Bennp2000 FLUENT 5 March 4, 2011 16:58
How to plot results in MATLAB risklotus Main CFD Forum 0 January 17, 2010 00:33
