Difficulty in understanding Coeff. of Drag of Airfoil |
April 9, 2017, 02:38 |
Maharshi
Rep Power: 9 |
Dear all,
I am finding difficulty in understanding the Coeff. of Drag and lift of a wing whose cross section is derived from Althaus AH 79-100A airfoil(link for coordinate file - https://m-selig.ae.illinois.edu/ads/coord/ah79100a.dat). The simulation was done in Star CCM+ R9 . The values obtained were, Cd = 0.2811885068982537 Cl = 5.196364470423872 The dimensions of the wing are Wing span (s) = 0.85417 m Wing chord (c) = 0.0982m Aspect ratio (AR) = 8.7 Angle of attack = 0 degrees Air velocity = 30 m/s Regarding mesh and physics continua Mesh Base size = 0.014(prism layers and vol. controls were employed around wing body) Physics model - K-epsilon. My doubt is that whether the values obtained are correct or resemble to real time values and if so then why the Cd is so high?(i have attached the picture of the domain and wing so that you can have better understanding).If the values are not justifiable then what may be the possible causes of error. Thank you in advance and your help is really appreciated. |
Airfoil lift and drag understimated | Kio | OpenFOAM Pre-Processing | 15 | October 1, 2016 14:48 |
Airfoil lift and drag using k-kl-omega turbulence model | hylleman | OpenFOAM Running, Solving & CFD | 6 | June 17, 2016 16:10 |
negative airfoil drag?? | Robin | FLUENT | 4 | January 7, 2010 17:29 |
calculating drag at low Re no over FX airfoil | M. Essuri | FLUENT | 1 | November 1, 2006 16:55 |
