March 22, 2017, 05:06 |
Pressure Spectrum
Amar
Rep Power: 9 |
Hello everyone,
I've a simple question , and hope to check with you. I calculate the one dimensional spectra of the pressure in streamwise in channel flow from DNS. My procedure is as follows: 1) get the fluctuations p_prime(i,j,it)=p_ins(i,j,it)-p_m(k) " For p_ins the instantenous field, p_m is the mean value at certain height from the bottom wall. (i,j,k,it) stand for (streamwsie, spanwise ,wall-normal,time), respectively. 2) get fft of p_rime ==> p_r+i p_i 3) get the spectra of E_pp(k_x)=(p_r^2+p_i^2)*(L_x/2pai) "L_x box length in x-direction" 4) Averge over spanwsie and time domains 5) check with the r.m.s of the pressure p_rms^2=Integration(-inf to +inf E_pp(k_x) d k_x ) "k_x is streamwise wave number" However, the resulting spectrum seems to be not smooth enough. In addition the curve is little bit lower than the expected value from other studies eve if the check is correct (step # 5). Sorry for this long explnation, but any suggestions will be appreciated. |
March 22, 2017, 05:10 |
Filippo Maria Denaro
Rep Power: 73 |
I have never worked on pressure spectrum, could you post your results?
Then, do you get good results for the velocity spectra compared to those in the database? |
March 22, 2017, 05:33 |
Amar
Rep Power: 9 |
Thanks for you reply,
the wall pressure spectra is attached. Actually, I follow the same procedure in the velocity spectra and I obtained reasonable results. I guess the same steps can be applied for the pressure. I'm sorry for this unintended mistake, Re=1000, based on the friction velocity. |
March 22, 2017, 05:39 |
Rep Power: 73 |
I don't see the plots... what about the Re number? could you post also the comparisons of the velocity spectra?
March 22, 2017, 05:57 |
Amar
Rep Power: 9 |
I'm sorry for the mistake. I reloaded the pressure spectrum.
the velocity spectrum at the y^+=15 is attached in loglog scale. |
March 22, 2017, 06:34 |
Rep Power: 73 |
I am no sure if the DNS database contains the pressure spectra, have you already checked there?
I have no experience in the pressure wavenumbers distribution for the channel flow but it seems reasonable, there is no theoretical reason to have an inertial slope like that in the velocity |
March 22, 2017, 06:53 |
Amar
Rep Power: 9 |
Some DNS data base provide the pressure spectra, like those of John Hopkins
http://turbulence.pha.jhu.edu/ I compared my analysis with them at the same Reynolds number and obtained a difference between the results. This makes me doubts about the methodology if it is like the velocity or not. Pressure is expected theoretically to introduce a k-1 slope in the intertial subrange at the high Reynolds number. However, this slope was just approched in the experiments introduced by Tsuji et al. (2007), and up to now, it is not achieved in DNS. |
March 22, 2017, 07:42 |
Rep Power: 73 |
Well, could you sumperimpose your pressure spectrum and that in the database? Start with y+ corresponding to half-height channel (you wrote 1000), I do not believe you have a theoretical inertial slope close to the wall.
dns, spectra |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
Outlet pressure | aja1345 | FLUENT | 5 | August 18, 2015 12:02 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
Sound pressure level (SPL) spectrum | cfd novice | CFX | 0 | October 12, 2008 12:15 |
