Grid Independence and Node Distribution
Old   March 21, 2017, 13:59
Default Grid Independence and Node Distribution
James
Chaoticzz is on a distinguished road
Hi all,
Just a quick question. I'm studying an expansion flow for a circular axisymmetric duct. When setting up a grid on the boundary, should I setup the optimum node distribution (i.e. towards the wall and expansion region) before doing a grid independence test (coarse, medium, fine) or vice versa?
Thanks
Chaoticzz is offline   Reply With Quote
Old   March 24, 2017, 02:22
Lane Carasik
lcarasik is on a distinguished road
Originally Posted by Chaoticzz View Post
Hi all,
Thanks
Hey James, just for clarification, did you mean have your near wall mesh set up to be valid and then do the mesh convergence study?
If so, yes I recommend an approach that ensures your near wall damping functions (near wall treatment/wall functions/etc) is properly resolved (this being used loosely). Then, leaving your near wall meshing alone, refine your bulk region of flow.
lcarasik is offline   Reply With Quote
Old   March 24, 2017, 05:26
James
Thanks for the reply Lane!
I'm restricted the the near wall treatment & wall functions I can use, say standard wall treatment for k-epsilon. I was talking more about the distribution of nodes. For example, shifting the nodes on the outlet pipe towards the expansion zone and also shifting them outwards towards the wall to produce a finer mesh to cover the vortices occuring on expansion.
Following this, then increase the No. of cells to determine independence.
Thanks
grid independence, node distrubtion
Node Number And Results ZenCef FLUENT 0 July 9, 2011 02:29
Grid independence James Main CFD Forum 2 March 10, 2009 14:41
Grid independence with k-eps model Mark Render Main CFD Forum 3 February 21, 2002 10:54
