Cylinder Drag coefficient discrepancies
Old   March 21, 2017, 06:57
Default Cylinder Drag coefficient discrepancies
MARKEL ROA FRESNO
MarkelRF is on a distinguished road
Hi Everyone,
I am analyzing the turbulent flow over a cylinder in 2D (Re=10^4) with STD & realizable k-epsilon models. For each model, I am running two sub-cases:
1- Both kinetic energy production limiter and curvature correction switched off.
2-Both of the previous ones switched on.
I have obtained drag coefficients of around 0.55 for the sub-case 1 after having run with both STD & realizable models.
I have obtained drag coefficients of around 0.7-0.8 for the sub-case 2 after having run with both STD & realizable models.
Nevertheless, I have found in the literature that the drag coefficient for this Reynolds number should be around 1.2. I understand there might be some differences between both submodels due to artificial kinetic energy being generated in the domain area of the front stagnation point, where the flow is irrotational in the 1st submodel. But I do not understand why there is such a discrepancy between the calculated drag coefficients and the one found in literature.
PS: The reference values are all well entered, including the transversal area (radius of the cylinder x depth (1m)).
Sent from my Nexus 5 using CFD Online Forum mobile app
MarkelRF is offline   Reply With Quote
Old   March 22, 2017, 21:02
karthi
karthikkumar is on a distinguished road
What is k-epsilon method
Sent from my T02 using CFD Online Forum mobile app
karthikkumar is offline   Reply With Quote
Old   March 23, 2017, 04:11
MARKEL ROA FRESNO
It is a two equation RANS turbulence model. It studies turbulent flow in an averaged way.
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 17:16
how to calculate drag force coefficient of cylinder in oscillating flow vhcongtltd FLUENT 10 September 25, 2014 05:59
How to calculate the drag coefficient for flow past cylinder o_mars_2010 Tecplot 0 April 18, 2013 02:26
problem with saving drag coefficient colopolo FLUENT 5 April 12, 2013 11:59
Calculation of Drag Coefficient, Help Please teek22 CFX 1 April 26, 2012 19:41
