Limiting the production of turbulent kinitec energy
Old   March 20, 2017, 02:20
Default Limiting the production of turbulent kinitec energy
New South Wales
tbwake is on a distinguished road
Hi all,
I am looking to best model vortices formed by a delta winged aircraft for an AoA range of -5 to 25 degrees using a steady state solver.
I have attached an excerpt of an AIAA paper I was reading (Integration of Multi-Fidelity methods for Generating an Aerodynamic Model for Flight Simulation), where they state:
"It is well known that most linear 2-equation turbulence models over-predict the eddy viscosity within vortex cores, thus causing too much diffusion of vorticity".
The referenced articles are:
Gordnier, R. E. “Computational study of a turbulent delta-wing flowfield using two-equation turbulence models”. AIAA 96-2076, 1996.
and a link to the second is:
http://reports.nlr.nl/xmlui/bitstrea...pdf?sequence=1
These both discuss the usage of a limiting term in the standard k-e and k-w models. I was wondering if anybody has any input on this topic or found this necessary when using either the realisable k-e or the SST k-w for similar simulations to mine.
Cheers.
tbwake is offline   Reply With Quote
Old   March 20, 2017, 07:18
Tarang
gtarang is on a distinguished road
I am also facing the similar problem my k-epsilon model, where I found I am over predicting the Production term and I followed "Turbulent Flows" by S.B. Pope for my studies. As the paper suggests limiting the production term, the Author of the book proves that the production term is actually bounded as (Exercise 5.21)
|P|<= 2*k*S(l).
k = Turbulent kinetic energy
S(l) is the largest absolute value of the eigenvalues of the mean rate-of-strain tensor.
I have not really tried limiting the production term till now because I am still studying whether the flow is stagnant there or not and should I limit the terms using explicit formulation of k.
Any discussion in this field will be helpful.
Thanks
gtarang
gtarang is offline   Reply With Quote
Turbulent Kinetic Energy for a one-equation model wgvanveen Main CFD Forum 0 March 25, 2015 07:26
turbulent energy spectrum cfd.newbie Siemens 1 June 20, 2008 00:48
turbulent energy spectrum cfd.newbie FLUENT 0 June 18, 2008 19:34
calculation of (turbulent) dissipation energy ? max Main CFD Forum 3 August 18, 1999 10:42
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
