March 14, 2017, 00:57 |
Flow Simulation
Prince Hossain
Rep Power: 9 |
Hi guys!!
I want to run a simulation on a duct of non frost fridge. Would someone please suggest me how many iteration i will do for a static setup. i want to calculate the average flow and temperature distribution in the duct. Thanks |
March 14, 2017, 01:46 |
Uwe Pilz
Rep Power: 15 |
I see two ways to come to an answer:
1) Let a simulation run and look after some simulated time whether the total thermical engergy still changes . 2) Calculate the Prandl number for your case. This gives you an idea how fast things change.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 14, 2017, 06:06 |
Prince Hossain
Rep Power: 9 |
i didn't catch it properly. will you please elaborate
March 14, 2017, 12:42 |
Uwe Pilz
Rep Power: 15 |
I recommend:
- calculate the Reynold number for the outer flow. For that you need some idea of the velocity . - calculate the Prandt number for the outer flow. You need the kinematic viscosity and the thermal diffusivity for that, which you may get from tables. For air is Pr~0.7 and for water at 20 deg Pr~7. - calculate the Nußelt number With the help of the Nußelt number you may calculate the maximal thermal flow (at starting temperature difference). Using the the heat capacity you may calculate how long it lasts to exchange all the energy. The real time will be longer, depending on what remaining difference you accept. But you get at least an idea in which range this time will be.
March 15, 2017, 05:32 |
Prince Hossain
Rep Power: 9 |
thank you so much for your answer. i am on it
cfd flow |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Flow rate restriction simulation set-up | siw | CFX | 4 | February 16, 2016 13:15 |
Numerical simulation of DBD plasma actuator induced flow | mukut | OpenFOAM | 5 | January 7, 2014 06:30 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 05:44 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 15:11 |
