Where can I find description of SIMPLEC?
Old   February 19, 2000, 05:22
Default Where can I find description of SIMPLEC?
Evgueny Kalabin
Hello, Friends
I cann't find the description of SMPLEC-algorithm in internet: I know SIPMLE and SIMPLER (I have Patankar's book), but I do need SIMPLEC. Would you pleased to write me back the information about this algorithm or some e-addresses where I can find it.
Thanks for help, Evgueny
Old   February 19, 2000, 18:08
Default Re: Where can I find description of SIMPLEC?
Ben
Try this book.
J. H. Ferziger and M. Peric, "Computational Method for Fluids Dynamics", Springer, 1996
Old   February 20, 2000, 22:40
Yan Ding
You may try the journal paper:
Van Doormaal J.P. and Raithby G.D.(1984), "Enhancement of the SIMPLE method for predicting incompressible fluid flows", Num. Heat Transfer, Vol.7, pp147-163.
Old   February 22, 2000, 03:02
Ulf E
Hi Evgueny You may find a brief description in H.K Versteeg & W Malalasekera "An introduction to Computational Fluid Dynamics, The Finite Volume Method"
Old   March 1, 2000, 12:19
Vladimir A.Prokofiev
About SIMPLER & SIMPLEC: I.A.Belov, S.A.Isaev, V.A.Korobkov. Zadachi i metodi rascheta otrivnih techeniy nesgimaemih gidkostey (RUSSIAN) . Leningrad, "Sudostroenie", 1989. Ranee Iy sam uspeshno ispolzoval SIMPLER (2-D).
Or, write to me! Prokofiev V.A.
Old   March 2, 2000, 00:14
Evgueny Kalabin
Hello friends Thank you very much, I found the SIMPLEC with your help. Sincerely Evgueny
Old   March 2, 2000, 05:49
See also good letter: D.S.Jang , R.Jetly, S.Acharya. (Luisiana State Univ.) "Comparison of the PISO, SIMPLER, and SIMPLEC algorithms for the treatment of the pressure-velocity coupling in Steady flow problems", Journal: Numerical Heat Transfer, vol.10, pp.209-28, 1986.
Best regards, V.A.Prokofiev.
Old   June 4, 2016, 17:55
Saman Mofid
samanvmofid is on a distinguished road
Originally Posted by Evgueny Kalabin
;7910
Dear Evgueny Kalabin
Can you tell me where you found about SimpleC method? I really need it.
Thank you in advance
Saman Mofid
samanvmofid is offline   Reply With Quote
Old   June 5, 2016, 11:48
Lane Carasik
lcarasik is on a distinguished road
Saman Mofid
This thread is very old and the authors of the original comments are not likely to respond.
This webpage should get you started on the SIMPLEC method.
https://engineering.purdue.edu/ME608...f%20SIMPLE.pdf
lcarasik is offline   Reply With Quote
Old   June 7, 2016, 05:14
Smile
Saman Mofid
Thank you very much for the reply
OpenFoam171: error /usr/bin/ld: cannot find -llduSolvers Schipper OpenFOAM Programming & Development 9 August 26, 2020 06:31
Looking for SUBOFF model but i can't find it. Heewon Lee Main CFD Forum 7 March 5, 2017 14:36
Ways to find Mass transfer coefficient using CFD? tuks_123 CFX 10 April 15, 2011 12:20
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
YPlus nowhere to be find Daniel CFX 3 May 1, 2006 17:22
