Mesh generation for 3d airfoil woth serrations
Old   February 20, 2017, 17:13
Default Mesh generation for 3d airfoil woth serrations
abhi
chhabraabhinav95 is on a distinguished road
M planning to analyze 3d airfoil with trailing edge serrations.but the problem is m not much familiar with the mesh generation techniques and which mesh should i use. The simulation will be for low subsonic flows.
I actually watched some tutorials for icem cfd but i didnt get much imformation which can help me.
So, Can anyone tell me how should i approch this problem in order to get valid result.like what kind of mesh is required.?
Thanku
Sent from my ONEPLUS A3003 using CFD Online Forum mobile app
chhabraabhinav95 is offline   Reply With Quote
Old   February 20, 2017, 18:55
Michael Prinkey
mprinkey will become famous soon enough
I am no meshing expert, but I can tell you that you've picked a challenging problem. I would mesh the top of the fluid serrations first (with triangles) and extrude them into wedges. That would fill all of the serrated flow volume. Then mesh the serrated solid surface also with triangles. Then try to mesh the normal surface of the wing with quads if possible. Then extrude all of those surfaces out to fill your flow domain with mixed hex/wedges. You should be able to control your mesh density well in the serrated flow area using triangles. Extruding those should give you good control of the boundary layer spacing. The same will be try extruding into the main flow area around the wing.
Good luck.
mprinkey is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] 2d Undtructured mesh around airfoil with boundary mesh samiyare ANSYS Meshing & Geometry 2 September 21, 2013 01:29
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
