Rotating Cylinder in ground effects 2D vs 3D
Old   February 18, 2017, 23:45
Default Rotating Cylinder in ground effects 2D vs 3D
Vinko Jezercic
Vinko is on a distinguished road
Hi guys,
Im doing a simulation of an open wheel racing car for my dissertation and im just running through a few test cases to justify my settings. Im currently stuck on simulating a cylinder tangent to a flat plate representing the wheel-road interface. I ran simulations for both the road itself and the cylinder in ground effects as 2D studies and my results were as expected. When i ran a 2D study of the cylinders as a rotating wall next to the ground I got some very weird results, namely negative drag?!?!??
I then ran it again as a 3D study and got a more realistic result, so a drag force. Any idea why this could happen? I know that a 2D study implies that the cylinder runs along the same width as the road, and the 3D study is able to model the two trailing vortexes which occur because the air slips over the edges of the wheel but it still seems wrong to me that a rotating cylinder (my 2D study) would have lower pressure at the leading edge as compared to the trailing edge thus causing negative drag
Sent from my iPhone using CFD Online Forum mobile app
Vinko is offline   Reply With Quote
Rotating cylinder analysis in Fluent sercan85 ANSYS 0 August 15, 2016 07:03
[ANSYS Meshing] complicated motion of a rotating cylinder? Vamsi ANSYS Meshing & Geometry 0 April 9, 2016 01:32
interFoam rotating cylinder pressure BC problem chrisb2244 OpenFOAM Running, Solving & CFD 1 August 12, 2013 02:37
Please help me!!!!!!! analysis of a semi salvage rotating cylinder in a fluid adambarfi FLUENT 2 June 14, 2012 02:53
flow below a vertical rotating cylinder hani Main CFD Forum 1 October 9, 2002 14:28
