Laminar transient or Turbulent steady state?
Like Tree7Likes
Old   February 13, 2019, 14:23
Lucky
You do laminar when the flow is laminar and turbulent when the flow is turbulent.
You use steady when the flow is steady and transient when the flow is transient.
Old   February 13, 2019, 15:13
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by vidyadhar View Post
Hello Lucky Tran,
Thank you for the reply.
If I want to simulate a natural convection problem over a heat sink, how can I decide that I have to use Laminar analysis or turbulent analysis when I change parameters like heat supply to the heat sink, dimensions of the heat sink etc.
If I have to do Laminar analysis, how to decide whether to chose steady state simulation or transient simulation.. if I am interested in steady state solution.
Thanks in advance!
vidyadhar
If you run a transient solver and your solution has a physical steady state, you will reach it after the time derivatives vanish. Conversely, running a steady state solver in a flow problem that does not admit a physical steady state will drive you to get oscillations in the residuals.
In any case, you need to know the physics of your problem if you want to do a correct CFD analysis.
A CFD code is only a stupid numerical algnorithm, it says nothing if you are not able to understand what you are doing
Reddy0 likes this.
FMDenaro is offline   Reply With Quote
internal flow, laminar to turbulent, steady and unsteady state
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Flow Across Tube Banks - Transient vs Steady State HeatTransferFan CFX 11 September 28, 2012 15:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
time to reach steady state with transient simulati prabhu CFX 2 April 21, 2008 11:18
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
