How many mesh elements per second per CPU core ? |
February 11, 2017, 10:05 |
#21 | |
I think we are comparing orange and apples here (or at least I was).
I have full respect for such uniform grid solvers, which I somehow expect to be much faster than anything unstructured. Still, I don't see how such codes could ever manage to deal with the complexity faced in any industrial context. About the many doubts I have: 1) I work with immersed boundaries, and I call total bullshit on it. There might be room for external flows and moving objects but, I have serious doubts for internal flows and anything static. We have a post hanging On the immersed boundary method (sorry arjun and FMDenaro, I still have to put together the data). 2) Even without considering the theoretical issues of the IBM, I'm not pretty much convinced that billions of cells are the way to go. For a turbulent supersonic combustion simulation you might easily end up with 20 scalars just as main independent variables that you cannot deallocate. Which means 160 GB of memory. Even if your uniform grid code doesn't require anything else to be stored, how are you going to postprocess or store that data? Not to talk about the RAM. This already requires a 20-30k dollar machine, that only today are starting to become available as workstations. 3) The previous point also reminds me of the https://en.wikipedia.org/wiki/Wirth%27s_law. 4) Not all problems can be reduced to a single poisson solve per iteration. Not an expert here, but I guess that anything non-symmetric is already out of the game. Which means you are still tied to a convective CFL limit to advance your solution (at least for practical cases where you need upwind). So, no matter how fast you solve your poisson system, you just moved your information of 1 cell (still 1023 missing to reach the other domain end). This, again, reminds me of point 3. 5) Typically, a grid is built to capture ineteresting things, which mostly happen at boundaries, so your minimum required cell count for a given problem might be something like N^2 with an isotropic octree grid. However, most of the times this is already overkilling as some directions might require much less points than others, and a good working grid is somewhere between N and N^2. You are instead proposing N^3 as working paradigm. Which reminds me, again, point 3, but also this: http://tfc.snu.ac.kr/jboard/file_dow...1405313764.pdf Obviously, and I know this because that's where I come from, turbulence research has other requirements, which much better fit this model. But that's already overkilling for LES. And how would you justify a 1024 cell resolution in a direction where most of the variations will only happen over 10-20 cells near the body (e.g., RANS)? @Michael: Quote:
@zx-81: You should really compare your solver with this http://www.incompact3d.com/ @arjun: In a world where the peer review process is already completely flawed (even jcp accepts complete bullshit and most reviewers, nowadays ,barely know a fraction of their own field), do you think that patenting a computational procedure has any sense at all (considering that you are actually paying for it)? I don't want to be disrespectful, I believe that your method works as expected etc., I literally mean what I wrote. Let me give you an example. Let's say that I copy any of these http://patents.justia.com/patents-by...fication/703/9 methods and I use it in my solver. They'll never know (those who filed the patent). Let's make a further step and say that i develop a software using such copied method and sell that software. They could still never know that. Let's say that they are paranoid and decide to sue me just because of a suspicion. Besides the cost of an international law action with all its large uncertainties, I can still prove that all the parts of any patented work at that page are copied from someone else who published decades before they could actually use a PC and I could barely change the order of the parts of the process to obtain a different process which I could file for a patent myself. What's the sense then of all this? I stress again that I do not mean to be disrespectful, I'm truly interested in the answer. |
February 11, 2017, 12:53 |
#22 | |
Bernd
Rep Power: 14 |
(But let's not start a general patent discussion as its off-topic here) |
stop when I run in parallel | Nolwenn | OpenFOAM | 36 | March 21, 2021 04:56 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
