Natural convection in enclosure with heat generating source
Old   February 2, 2017, 04:03
Default Natural convection in enclosure with heat generating source
Swapnil P
nuclear_swapnil is on a distinguished road
Facing big confusion regarding understanding of the flow in enclosure with heat generating strip at the middle.
The strip is placed in the middle of the square enclosure and generating uniform heat. The top and bottom walls are adiabatic and vertical side walls are isothermal at ambient temperature. The temperature profile and velocity profile is similar on both side of the strip but how come the intensity of the contours (stream function) is different on both sides of strip?
For reference providing the stream function, isotherms and velocity magnitude profile.
nuclear_swapnil is offline   Reply With Quote
Old   February 2, 2017, 04:34
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The solution seems reasonable, is steady (very low Re number?) and symmetric, the temperature field show a stratification. What is strange is that you do not have zero velocity at walls
FMDenaro is offline   Reply With Quote
Old   February 2, 2017, 04:43
Swapnil P
Yes its steady state natural convection problem with high Rayleigh number 10^9. Also, the amount of heat generation is very low as compare to the length of the geometry.
Old   February 2, 2017, 04:55
and the velocity at the walls??
Old   February 2, 2017, 05:10
Swapnil P
At the wall velocity is zero. I have scaled up the vectors for better view therefore it shows flow at the wall but actually it is near the wall.
Old   February 2, 2017, 05:26
Ok, then I don't see problems in the solution...just consider to do the grid refinement study to assess convergence of the solution
Old   February 2, 2017, 06:36
Swapnil P
Actually, there is no problem in the solution but the understanding of the stream function in the enclosure, which is not uniform inside the enclosure. If you check the stream function contours, it is more intense on one side of the heat generating strip as compare to other side. How come this is possible?
Old   February 2, 2017, 06:44
could you plot the contour lines instead of the shaded contour? I suggest to superimpose the streamline contours to the vector plot....when two streamlines are close, the velocity is greater than when they are more far..
ansys fluent, fluid flow, heat transfer, natural convection, stream function
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
Natural convection in oil filled enclosure abu250feldman FloEFD, FloWorks & FloTHERM 5 December 4, 2013 10:37
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 05:22
