Although having reduced the time step, the simulation is not converging
Like Tree12Likes
Old   February 8, 2017, 18:53
Hector Redal
HectorRedal is on a distinguished road
Originally Posted by FMDenaro View Post
Good, that's what I expected.
However, you still can not be sure of further bugs in your code. The lid driven cavity test-case does not help in this assessment (we can discuss a lot about why) and you should still consider the analytical test-case to compute the solutions on several refined grids both while taking dt/h= constant and using via via refined time step fixing one grid with the smallest h you can use.
For sure, that there are more bugs in the code. One cannot be sure that your software is 100% free of bugs. That is true not only for the code developed by me but for any existing developed code (even commercial).
Not only have I tested my code with the lid cavity flow, but with a test case that simulates a flow through a two-dimensional rectangular channel with non-slip condition in the walls. Solution to this problem is well-known. The expected flow pattern is a parabolic profile.
I have also performed a convergence study taking dt/h constant.
I obtained the same order of convergence than for the lid driven cavity flow with less than 0.1% of deviation error from the theory.
HectorRedal is offline   Reply With Quote
Old   February 8, 2017, 21:16
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by HectorRedal View Post
Hi Arjun,
I really appreciate your help and support on this issue.
I would like to comment that finally I have found an error in the code when retrieving the value of the pressue from the previous step. There was an initialization error in a loop that iterates over the nodes of the TRIA element.
After having fixed the error, I have tested and it (reducing the time step), and it appears that it is working now.
I have tested with delta T = 10e-6 and even with 10e-7, and the solution does not blow up at all. It really provides quite accurate and good results, at first sight.
Thanks a log for your help.
BR
Glad that it worked out.
This is what makes CFD very difficult that when things don;t work we can not say anything with certainty.
arjun is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
time step directories naming issue Andrea_85 OpenFOAM 3 April 3, 2014 09:38
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
