Boundary Layer Thickness is Non-Developed Internal Flow |
January 31, 2017, 12:50 |
Obad
Rep Power: 13 |
Hi guys,
I'm simulating the flow through a complex shaped nozzle with undeveloped flow (due to mixing and flow separation). Now I would like to determine (approximate) the boundary layer thickness to get the flow properties at the boundary layer edge. The criterion with 99% of the free stream velocity doesn't work in that case, because there is no uniform free stream... Do you have any ideas? Cheers! |
January 31, 2017, 13:34 |
Filippo Maria Denaro
Rep Power: 73 |
Sorry, but I think that your question is not well posed, for your problem it appears not correct to talk about a real BL ... Maybe you can give us the details so that the question is better addressed for this case.
February 1, 2017, 05:48 |
Obad
Rep Power: 13 |
My case deals with the determination of the heat transfer over the nozzle walls. In order to proplery resolve the flow next to the wall I'm using a hybrid grid with a structured grid (prismatic layers) at the wall.
To check if the used prismatic layer is thick enough I wanted to measure the boundary layer extend. I tried to define the boundary layer thicknes by using the total temperature profile which according to compressible boundary layer theory should show an overshoot close to the boundary layer edge. However, in some parts of the flow this overshoot appears to happen much further away from the wall as you would expect it to be... Additionally I would like to define the heat transfer coefficient by using the boundary layer edge properties for defining the recovery temperature. |
February 1, 2017, 06:11 |
Rep Power: 73 |
Without details of your flow problem I can just have an idea...but to define a boundary layer thickness you should argue that it exists an external inviscid-like region...and from what you wrote I see a totally internal confined flow.
February 1, 2017, 08:07 |
Obad
Rep Power: 13 |
As I said it's the flow through an ordinary rocket nozzle. The nozzle is overexpanded which leads to flow separation.
There definietely is a inner region with constant (almost zero) vorticity which could be considered as the potential flow. However, defining the boundary layer as the region with vorticity leads to very high vaules (approx. 40cm). Since it is an accelerated flow I suppose the boundary layer should be much thinner. |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
