sliding grid
Old   February 16, 2000, 13:00
Default sliding grid
Rémy Tasse
Does anyone has experience of CFD analysis with sliding grids? I would like to know what are the possiblities of this technique and with which commercial codes ? I also need to understand how we can control the motion of the grid and how it is linked to unsteady flow computation. Thanks
Old   February 17, 2000, 09:09
Default Re: sliding grid
wang haigang
Dear sir,
I have calculated the flow in the intake port and cylinder of engineering with moving valve and piston. The code named KIVA-3,in this code you can calculate the slid mesh using the new method called "snapper". wang haigang 2/17, 2000
Old   February 17, 2000, 10:38
kang
Fluent 5 has the capability of simulate sliding mesh, example like turbine machine is a typical application. You may want to look into the Fluent forum, there is a thread talking about sliding mesh I think.
Old   February 17, 2000, 10:54
Erik Torbergsen
I have used CFX4 with sliding grids quite successfully to study rotating stall in a centrifugal pump. The simulation was quite qualitative, but typical parameters such as stall propagation velocity was very well predicted. If you want some more details, I can send you info about it.
Regards
Old   February 17, 2000, 13:49
John Law
Mesh sliding means that you have relative movement between neighbouring blocks such as staor/rotor interaction or valve movement in Internal Combustion Engine, thus the flow is normally transient- if you are familiar with unstructured mesh methodology, then this simply means that at the interface, the cell connectivities changes dynamically. For a structured mesh, you can alternative use shear-click type of sliding mesh. I believe all three commercial codes listed in the Forum have this capability.
Old   February 18, 2000, 06:06
Chris du Preez
Hi, I have used Flo++ for the modelling of a projectile as it moved past the muscle break (in other words a very fast piston leaving the flow domain).
I think Flo++ uses an arbitrary face coupling at the sliding interface.
sliding grid problem cheminer FLUENT 0 October 13, 2009 03:00
SLIDING GRID ADVANTAGE Sam Main CFD Forum 0 October 8, 2008 06:20
Grid check fails after sliding mesh calculation Tito FLUENT 0 March 3, 2008 15:28
Grid angle in sliding meshes mystic_cfd FLUENT 0 October 1, 2002 07:07
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
