Implicit discretization of Jacobian term in FV: Construction of Coefficient matrix |
January 19, 2017, 07:31 |
Santiago Lopez Castano
Rep Power: 16 |
I am currently trying to write the linear system coefficients of the following system:
But I cannot get my head around on how to come up with the coefficients for the jacobian fluxes. I mean, I see a tensor that needs to be projected along $\mathbf{n}$ and from it you do the discretization. My attempt on this enterprise is (the simplest, I think): What makes me uneasy is the fact that is a vector. Thus, Are the coefficients for each of the vector's components equal to the face-normal projected distance between the neighboring centroids? |
January 19, 2017, 07:45 |
Filippo Maria Denaro
Rep Power: 73 |
I do not understand your symbolism...
1) the first term in the LHS is the time derivative of u?? 2) Since the first term is a vector, the second term in the LHS is the integral of a tensor (uu??) projected along the normal unit vector to the surface n. For example, Int [S] n.uu dSIn your equation the symbol du/dn is still a tensor (why is d(du)?). The Jabian of the flux can be derived from the differential form starting from df/dxi = (df/dui)*(dui/dxi) |
January 19, 2017, 08:55 |
#3 | |
Rep Power: 16 |
2.) The the second term is just a diffusion transformed in a flux using the green-gauss theorem. What I want is to get the coefficients of A, for the system: Part of the diagonal terms are given by the first term of LHS, but my question is how to discretize the second term. Thanks. |
January 19, 2017, 09:28 |
Rep Power: 73 |
thus, using Gauss you have a surface integral like
Int [S] n. grad u dS why do you need to introduce a Jacobian? you can directly discretize the integral of the fluxes |
January 20, 2017, 05:35 |
Rep Power: 16 |
I referred the derivative of the vector function as jacobian. My bad.
Sent from my GT-I8190L using CFD Online Forum mobile app |
finite volume method, linear system |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
FVM discretization of diffusion term on crvlnr gr | Michail | Main CFD Forum | 3 | March 14, 2008 07:52 |
Convection Term Discretization | Maciej Matyka | Main CFD Forum | 3 | October 7, 2004 05:32 |
Coefficient matrix | Question. | Main CFD Forum | 1 | September 12, 2004 22:19 |
