FVUS (Finite Volume Utilities and Solvers) / Wildkatze (solver) Updates
Like Tree3Likes
Old   May 24, 2017, 18:34
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by FMDenaro View Post
What about the developing stage of dynamic LES modelling?
Dynamic SGS is available in the version about to be released in a week or so.
Fluent has transport equation for k based LES too along with dynamic procedure.
This needs to be added as currently FVUS only has k transport based LES and no dynamic version of it. This i will do as i get time.
PS: Also added bounded central differencing for LES flows.
arjun is offline   Reply With Quote
Old   May 24, 2017, 18:37
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks,
Is it possible to set bounded or unbounded central difference?
Have you performed some test?
FMDenaro is offline   Reply With Quote
Old   May 24, 2017, 19:42
Arjun
Thanks,
Simple tests are done but i think a more serious test needs to be done.
I take it up and also need to add the inflow turbulence generator.
Old   May 25, 2017, 07:07
Ok, let me know about your progress in doing the test-cases.
Thanks
Old   May 25, 2017, 07:52
Arjun
Thanks
I probably get some time in first week of june. Do you have any preference for the test case. I see if I could do that.
Also
At the moment unbounded or unlimited versions are not available, but I think your idea has merit and user shall be able to set the "unboundedness" . That means that user shall be able to set limiter-min and limiter max that solver shall respect.
And by adjusting these to 1,1 one shall be able to get unbounded versions of these schemes.
I will keep this as a feature for future releases.
It isn't this simple in FVUS though because solver has automatic cell quality remediation built in and that likey to hinder this limiting when cell quality drops. So may be with assumption that user created mesh where all the cells are above certain cell quaility this can be provided.
(Also if cell quality is bad then unbounded may be unstable anyway).
FMDenaro likes this.
Old   May 25, 2017, 08:02
I suggest to do the test for the planar channel flow at a certain Re_tau value. It would be useful to check the code in DNS conditions before doing LES.
If you are interested, you can try to use the same grid parameters we used in this study where several CFD codes were tested:
https://www.researchgate.net/publica...blicationTitle
Old   May 25, 2017, 08:15
Arjun
This is extremely useful in many ways. I thank you for this.
I see that you are one of the authors, so if you have mesh lying around then it would be even better as apples to apples comparison could be made.
Also gives me opportunity to test/improve the code and also is helpful for user as he can then have some trust in FVUS (being pretty new code).
PS: Is it possible for you to mail me pdf of it at arjun.yadav@yahoo.com
Old   May 25, 2017, 08:27
We used a structured constant 64x64 grid in the homogeneous plane and two different stretched grids along the normal-to-wall direction. Details are in the paper so that you can use exactly the same resolution. You see that we computed also the no-modelled LES.
Old   May 25, 2017, 08:36
Arjun
Thank you I try to follow it.
By a quick glance saw an interesting comment about Fluent's bounded scheme that it had dissipation. Will see how FVUS does. Thank you again.
PS: Also got your mail too.
Old   May 30, 2017, 23:53
Arjun
FVUS Release 1.2 Beta is available from today to be downloaded from www.dravvya.co.in
Additions
Reactive Flow
  • ReactingSpeciesModel and FractionalFlowModel
Work together to provide finite rate combustion framework.
Turbulence
  • Standard K-Epsilon Turbulence Model
  • Dynamic Smagorinsky Subgrid
  • Bounded Central Differencing for Flow.
Firekatze
Firekatze is a separate product aimed at chemical reaction dynamics.
Current version of Firekatze translates CHEMKIN input files to FVUS format so that they can be further used for setting up simulations for Reacting flows.
Second task that Firekatze performs is of bundling species of similar transport properties into groups. This significantly reduces diffusion coefficient calculation times during simulation.
Note:
It is termed beta release as Reacting Flow model goes into further validations and tests. It is likely to add further options as users try to test and request additional features into it.
Also for this release Windows version is not available.
Old   July 22, 2017, 04:27
Arjun
Uploaded a video tutorial outlining a simple workflow with FVUS Wildkatze.
https://youtu.be/tgB8wedPhpA
Please use the highest resolution on youtube to see it clearly
NOTE
The pdf and mesh files etc shall be available as part of solver download. The latest version shall be uploaded soon this week sometime. The workflow is applicable to currently available version too.
fvus, wildkatze
Documentation for solvers and utilities? rendagar OpenFOAM Running, Solving & CFD 1 October 17, 2013 04:57
