Does pressure drop equals the dissipation within the fluid domain |
YuJi
Rep Power: 10 ![]() |
Hi friends,
I have the doubt in determining the loss of flow through the numerical simulaiton usinf FLUENT. I took two ways to calculate the results associating with the loss, one is the pressure drop, the other is the integral of dissipation (viscous+turbulence dissipation), but there always exists big difference between the two results. The case is a developed flow in a circular tube, the turbulence model i adopted is standard k-w model, the pressure drop at different Re number were validated against several semi-empricial correlation. |
dissipation, fluent, pressure drop, turbulence |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
Dissipation versus pressure drop | Fabian | Main CFD Forum | 1 | October 19, 2001 12:46 |
