Flow Inside a Funnel
Old   December 21, 2016, 07:25
Default Flow Inside a Funnel
Rajat soni
rsoni451 is on a distinguished road
Hello Everyone,
I am doing a simulation of PAN Precursor spinning process. The whole setup is submerged in the solvent(Please refer to the figure) and the wall of filament bundle as shown in the figure is moving at 0.03333 m/s. Some of the solvent flows out of the funnel because of the moving wall and to compensate that four pumps(2 pumping in and 2 pumping out) are installed in it. Until now, I have been using the solvent outlet as a pressure outlet and trying to find out the mass flow rate through the Report feature present in Fluent only. But I am not satisfied with the results I am getting. I am wondering if it is the problem with Solvent outlet boundary conditions or what.
I shall be highly grateful if anybody can help me out with this!!!
thanks in advance.
rsoni451 is offline   Reply With Quote
mass flow rate, moving wall, outlet boundary condition
Flow inside a Partially filled rotating cylinder vikrish FLUENT 0 September 13, 2016 04:56
Flow through small cylinder recirculated inside larger cylinder. Keesie FLUENT 1 July 28, 2016 05:30
Tutorial 12. Cold Flow Simulation Inside an SI Engine. Fluent 6.2 hesham FLUENT 0 February 13, 2016 09:24
Laminar flow inside a filter holder problem with convergence sachinip FLUENT 0 September 4, 2015 11:53
Separation bubble inside a tunnel - unexpected assymetric flow Queiroz CFX 8 November 27, 2014 18:27
