High Head Low Flow Centrigugal Pumps Design
Old   December 20, 2016, 02:39
Default High Head Low Flow Centrigugal Pumps Design
Rokson K Mathew
roksonkmathew is on a distinguished road
I am having trouble designing a high head low flow centrifugal pump with a certain power limit. What parameters will help obtain high efficiency?
A few parameters
1. Speed of the motor
2. No. of blades
3. Inlet and exit angles
4. Specific Speed
5. Exit width
For example, I am trying 25-40 (ft-usgpm)- speed 3600rpm, Specific Speed-2200- no. of blades-7, wrap-110, angle- 26 at inlet and 27.5 at outlet. dia 55mm, exit width-12mm, eye dia-30mm.
With these parameters the pump efficiency is barely reaching 60 % and also flow separation on the suction side.
What changes to the above parameters can improve the present design.
Thanks in advance
Regards
Rokson
roksonkmathew is offline   Reply With Quote
Old   June 15, 2017, 10:42
王莹
Alisa_W is on a distinguished road
Originally Posted by roksonkmathew View Post
A few parameters
2. No. of blades
4. Specific Speed
5. Exit width
Thanks in advance
Regards
Rokson
Hello,could I know which solver didi you use and how you set the interface of rotor and stator?Thanks a lot!!
Alisa_W is offline   Reply With Quote
centrifugal pump, design, design parameters
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 02:19
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure vinguva OpenFOAM Running, Solving & CFD 2 March 7, 2016 23:46
Boundaries for siphon flow and low head kjetil OpenFOAM Running, Solving & CFD 0 September 29, 2009 19:17
Flow solutions over airfoils at high aoa UYGUN CFX 0 October 8, 2002 15:23
CFD code for very low Re Flow Raj Main CFD Forum 2 May 31, 1999 22:06
