Simulating a Laminar Isothermal Flow in a 2D rectangular Channel |
December 18, 2016, 12:01 |
Hector Redal
Rep Power: 17 |
Hi
I am simulating an isothermal flow (not taken into account energy equation) in a 2D rectangular Channel. At the inlet the boundary condition is a uniform velocity inlet (constant). On the wall boundaries there is zero-slip condition. What I am observing is that the flow along the chanel is not constant. As the flow goes downstream, the flow decreases. At the begining of the channel there is a 1m/s x 1m flow, but at the end of the channel there is a 0.9 m/s x 1m flow. If I reduce the time step, the flow at the end of the channel tends to 1 m/s x 1m (0.95) but not reaching the inlet value (1). In my opinion this is not correct. But I don't know if reducing the size of the mesh, this effect will be fixed. Best regards, Hector. |
December 18, 2016, 12:41 |
Filippo Maria Denaro
Rep Power: 73 |
Check the flow rate, it must be the same at each location... if not, you are solving bad the divergence-free constraint.
The velocity must accelerate at the centerline. |
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 18:46 |
Plotting Nusselt's number and Flow in a rectangular Channel | yomilayeni | FLUENT | 0 | October 10, 2015 06:22 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 17:26 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 08:45 |
Help on laminar oscillatory channel flow [Help needed - Urgent] | Dtkcby | Main CFD Forum | 0 | March 19, 2011 16:11 |
