December 17, 2016, 13:20 |
RANS Vs LES
Polard
Rep Power: 11 |
My Question is , will LES give the same field after averaging over time(any flow field Quantity) as given by a RANS model?
I am trying to simulate jet flows and I am getting matched profiles with experiments in case when I used RANS Model(K-omega) but when I applied averaging over time in LES then i was not able to get same results. |
December 17, 2016, 13:52 |
Alex
Rep Power: 49 |
A LES -when performed correctly- is supposed to yield the same statistics as a DNS or an experiment. Not necessarily the same statistics that a RANS method would produce because of the inherent flaws of this approach.
December 17, 2016, 13:54 |
Filippo Maria Denaro
Rep Power: 73 |
The two fields are not exactly the same... for RANS you compute directly for <v> while for LES, after you average the solution you get <v_bar>.
If the difference is disregardable or not would depend on many factors. |
December 17, 2016, 14:31 |
Polard
Rep Power: 11 |
Thank u Sir , for your Quick Reply
But I am little confused as I want this difference to be as small as possible. I am trying to model the jet noise for which I need to do LES to resolve audible range of frequency emitted from the jet. When I applied my boundary conditions initially For RANS model ( Free stream Exterior, Nozzle as Free Stream inlet) I got the flow profile quiet close to experimental data, on the other hand the averaging over time done in LES gave different results. According to you what parameters should I change(experiment) in an standad LES model as it is very time consuming. |
December 17, 2016, 15:31 |
Rep Power: 73 |
The difference exists always by a theoretical point of view and depends on the size of the filter in LES. It can or not be highlighted by the statistics.
However, I first suggest to check carefully that your LES solution is good! Therefore: check the grid resolution, use the dynamic SGS model, use a high order discretization (space and time), be careful to compute the time-averaging only after the numerical transient (due to the numerical initial condition) is disregarded, perform the averaging on a sufficient number of samples. It would be useful if you post the results in terms of plot of RANS vs. LES |
Model Switch, RANS to LES? | jennap223 | STAR-CCM+ | 0 | July 7, 2015 12:30 |
Transition RANS to LES during simulation | LorenzN | OpenFOAM Running, Solving & CFD | 4 | November 17, 2011 11:47 |
Laminar Flamlet RANS to LES | LB | FLUENT | 0 | September 5, 2007 06:35 |
Mapping RANS data onto an LES | christian | OpenFOAM Running, Solving & CFD | 0 | April 13, 2007 06:31 |
RANS results for LES | Li Yang | Main CFD Forum | 5 | June 17, 2002 06:34 |
