December 14, 2016, 11:21 |
Cell Re as turbulence estimation
George
Hello everyone!
I have the following problem: Let's consider a pipe that evolves into a complex geometry. We can calculate Re in the pipe, based on its dimensions, but we cannot use this expression for the rest of the geometry. Can I instead do the following: Use a uniform mesh across the whole geometry (equally-sized elements) and then look at the values for Cell Reynolds number, and then compare the values in the geometry to the values in the pipe, and estimate how many times the turbulence increases outside of the pipe? If it is, let's say, 10 times, and I know that I have Re=4000 (from expression) in the pipe, can I state that I have Re=40000 in the geometry? thanks! |
December 14, 2016, 12:21 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
No, the cell Re number is a computational parameter, it is not meaningful of the global Re number based on the integral lenght scale....if you diminuish the cell size your cell Re dimuishes according to the grid size but the physical problem remains the same. Chose the integral lenght (for example the size of the pipe) to estimate the Re in pipe or use the characteristic lenght of a body (if present) in the rest of the geometry. |
Cell reynolds number and turbulence | Gavrilo Bozovic | Main CFD Forum | 2 | December 11, 2018 04:13 |
Displaying Turbulence Intensity in LES and creating a constant Turbulence Intensity | Anwer | FLUENT | 1 | August 8, 2016 17:59 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 05:30 |
Help Me, what's the Cell Above in 3D. | gomane8 | Main CFD Forum | 0 | September 10, 2011 20:09 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
