Cell_Function_Values: No post-processing value exists |
December 13, 2016, 23:44 |
lixinjun
Rep Power: 13 |
Hi everyone.
I write a UDF to describe the time-varying shape of a vibrating cantilever beam. I have two models to calculate: Fig.1(only air zone);Fig.2(air zone with a copper block), see attached file. The problem is when I use the UDF to calculate the 1st model, it worked well. But when I use the same method to calculate the 2nd model, an error appeared. I can’t save the .dat file both autosaving or manually saving. The Error message as follow: Host receiving summary from compute node zero. Writing "C:\Users\LXJ\Desktop\HS\C\fluent.dat"... turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 479944 cells Primitive Error at Node 0: Cell_Function_Values: No post-processing value exists. Primitive Error at Node 2: Cell_Function_Values: No post-processing value exists. I am not sure how to carry out this problem. Thanks in advance |
udf |
post processing for CEL expressions | Niru | CFX | 0 | May 10, 2013 14:13 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 07:21 |
CFD post processing techniques & streamlining | klk | Main CFD Forum | 0 | October 19, 2010 08:37 |
fluent for post processing | James | FLUENT | 0 | April 21, 2006 05:43 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 21:51 |
