Dávid Cziráky
Rep Power: 0 ![]() |
Dear all,
I modeled a honeycomb as a porous cell zone condition in a larger model for straighting the flowfield in a confuser. I had the datasheet for its pressure drop, so I could obtain the inertial and viscous resistance coefficients from its equation. (~1 and ~6.5) But I dont have any data regarding the two other dimensions. I use e+08 factor for these directions, but I can see some recirculating zones in the porous media, which is not so realistic. Have anyone modeled or worked with a honeycomb as a porous zone? I am looking for the proper order of magnitude for these two other directions, which are normal to the flow direction through the honeycomb. Thank you in advance! Greetings, David |
honeycomb, porous cell zone |
buoyantBoussinesqSimpleFoam with porous zone (source term) problem | cissystef | OpenFOAM Running, Solving & CFD | 0 | May 26, 2015 08:05 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Different phase in each cell zone condition | furieribruno | FLUENT | 0 | May 3, 2013 10:35 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
