High inlet Turbulence vs Low inlet Turbulence
Old   December 2, 2016, 00:03
Default High inlet Turbulence vs Low inlet Turbulence
Sana Ullah
Mehar is on a distinguished road
Hi everyone,
I am simulating steady state flow around a set of buildings using k epsilon model.
The problem I am facing is that, if I set higher values of inlet turbulence (40%), I get a well converged solution, but incase I use lower values of turbulence (10%), I don't get a stable solution (residuals oscillate irregularly)
What could be the reason?
One probable reason that I found on ANSYS website says that "Higher turbulence at inlet may swamp the boundary layer".
Is there any other explanation to this, or someone can further explain the ANSYS statement.
Mehar, Phd Scholar
KAIST, Korea
Mehar is offline   Reply With Quote
cfd analysis, inlet bc, turbulence
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
inlet size vs turbulence zdunol Main CFD Forum 3 September 24, 2014 05:43
Inlet turbulence conditions from given data siw FLUENT 0 July 8, 2013 10:13
High Re K Epsilon vs Low Re K Epsilon Ruonin Main CFD Forum 4 February 23, 2012 20:56
High depression at low alpha inlet (interFoam) santiagomarquezd OpenFOAM Running, Solving & CFD 0 June 1, 2010 18:18
