Mesh Grid Study - Result Tolerance - Lift, Drag, Moment.
Old   November 9, 2016, 12:40
Default Mesh Grid Study - Result Tolerance - Lift, Drag, Moment.
William
Wingman is on a distinguished road
I'm trying to find the correct density of my Airfoil Mesh. I have results of lift, drag and moment of the Airfoil using 20x meshes with Number of Cells between 4.000 and 600.000 with fixed velocity and fixed angle of attack.
Let's assume that the finest mesh gives the 'correct' results but I would like to find the coarsest mesh that gives correct results within some tolerance.
Are there any rule of thumb of tolerance? I've been using Lift Tolerance, Drag Tolerance and Moment Tolerance of 0.01, 0.0001 and 0.01 respectively but I'm not sure if they are correct. According to them my grid isn't converged yet.
Here is an example of the results.
Cells .....Drag Coeff ..... Lift Coeff.......... Moment Coeff
397150 | 4.719471e-02 | 7.436299e-01 | -1.096162e-02
480996 | 4.817767e-02 | 7.527957e-01 | -1.121976e-02
572866 | 4.770149e-02 | 7.576630e-01 | -1.125989e-02
I don't have measured data so I don't know the true values.
Wingman is offline   Reply With Quote
Old   November 9, 2016, 14:47
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The key to a successful grid sensitivity analysis is controlling all other sources of error and making sure their contribution is much lower than the error you expect from the spatial discretization.
It would be better to use relative tolerances instead of absolute tolerances with different magnitude.
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
flotus1 is offline   Reply With Quote
Old   November 9, 2016, 19:29
William
Thanks for this, just tried this method using the numbers I provided in first post. The results are for for drag, lift and momentum respectively (vertical) and for {21} and {32} horizontally.
φ_ext =
-0.4755 -0.4165
-7.4158 -6.5702
0.1106 0.0967
e_a =
0.0100 0.0204
0.0064 0.0122
0.0036 0.0230
e_a_ext =
1.1003 1.1157
1.1022 1.1146
1.1018 1.1160
GCI_fine =
0.1366
0.0879
0.0488
So... Am I supposed to use:
0.1366 * 4.770149e-02 = 0.0065 (instead of 0.0001 for drag)
0.0879 * 7.576630e-01 = 0.0666 (instead of 0.01 for lift)
0.0488 * -1.125989e-02 = -0.0005 (instead of 0.01 for momentum)
Old   November 9, 2016, 19:40
flotus1's Avatar
Alex
Take a look at your drag results: they either show oscillatory convergence or there is an error not related to the cell size. Either way, extrapolating the results is not an option.
To be more clear: have you made sure that all other sources of error are negligible compared to the spatial discretization error? I am especially thinking about iterative errors from running too few iterations.
Old   November 14, 2016, 17:50
asdfad
Drunken_SheeP is on a distinguished road
Have you checked there is really no more change in the values with more iterations? Also, how did you refine the grid? Did you refine all grid parameters equally?
Drunken_SheeP is offline   Reply With Quote
airfoil 2d, convergance, result, tolerance
How to calculate lift, drag and lift distribution in Star CCM+? israelcasillas94 STAR-CCM+ 4 November 6, 2020 09:35
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
[ANSYS Meshing] grid study, important questions hamid1 ANSYS Meshing & Geometry 2 February 10, 2012 14:28
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 11:38
