Compressible Wall Function
Old   October 28, 2016, 05:07
Default Compressible Wall Function
Ashwani
AshwaniAssam is on a distinguished road
I would like to know if anyone can help, how is compressible wall function need to be implemented in a CFD code with Spalart Allmaras turbulent model.
A few question apart from any other help anyone can offer in this regard are: I am trying to implement the Enhanced wall function as given in fluent manual https://www.sharcnet.ca/Software/Flu...ug/node514.htm
1. The van-Driest transformation is applicable only to log region or even in viscous sub region?
2. The temperature law of wall has a term q. Does this q is only wall heat flux or wall heat flux combined with viscous heating term (tau_w * V).
3. The value of dynamic viscosity, thermal conductivity required for calculating terms like y_plus, Pr, etc.. is to be taken at wall or at first cell near the wall.
Any help even if any one has a thesis doing the similar thing will be highly appreciated.
Thanks.
AshwaniAssam is offline   Reply With Quote
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 12:55
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 05:29
