October 26, 2016, 06:53 |
Triggering turbulence in natural convection
Agustín Villa
Rep Power: 15 |
Hello
my question is referred to the triggering of turbulence in LES and DNS in natural convection. It is widely studied how to trigger it in forced convection (like sinthetic turbulence, providing momemtum sources, buoyancy terms...), but I would like to know if those methods are valid too for natural convection, or if there are other methods to do that. In my case, I have a natural boundary layer. Turbulence is expected to develop by itself, but it seems it take so much time. I am imposing a fixed heat flux in the wall. Thanks for your attention! Agustin |
October 26, 2016, 09:14 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
October 26, 2016, 10:13 |
#3 | |
Agustín Villa
Rep Power: 15 |
I tried before, but since my incoming flow has a constant temperature, it dissapear quickly. However, I can try to play a bit with it. I was thinking to use a fluctuating heat flux q_w(t) in the wall. At the end of one period, the given heat should be the same, and I start provoking fluctuations close to the wall. Up to know, in 2D and fixed value of q_w it appears a fluctuation, but when I go for a 3D, a beautiful laminar profile appear, so I don't know how to make it turbulent. Thanks for your interest! |
October 26, 2016, 10:20 |
#4 | |
Rep Power: 73 |
you should superimpose a disturbance to the initial velocity field and let the BC.s unchanged... if the flow solution dumps the disturbance, it is likely you have too much dissipation (numerical or due to the SGS modelling) |
October 26, 2016, 10:22 |
#5 | |
Agustín Villa
Rep Power: 15 |
I am using a second order upwind for my divergence schemes, but I can move to a centered scheme, if my Peclet is not so big. This is the cause of a big dissipation, isn't it? |
November 7, 2016, 08:02 |
david
Rep Power: 14 |
Just be careful. Adding random signals would mean not satisfying the Navier stokes
November 7, 2016, 08:17 |
#7 | |
Rep Power: 73 |
1) the noise has a very small amplitude 2) at t=0 you compute the pressure equation with a source term that take into account the perturbed field in order to get pressure gradients that ensure the divergence-free constraint. |
November 7, 2016, 21:56 |
david
Rep Power: 14 |
How about putting point vortices at the inlet? By incorporating the Biot-Savart law, there will be an induction of velocities and you will get your fluctuations
November 8, 2016, 03:33 |
#9 |
Rep Power: 73 |
This would cause problems... The perturbation has just the goal to force the onset of the turbulence, but it is a numerical perturbation (has not correlations like in real turbulence) therefore the flow solution must lose memory of the initial perturbation. Usually, before to get a physical developed turbulence the code must run for some time in order to eliminate any trace of the initial condition.
UDF of natural convection in 3D cylinder | a_Sarlak | Fluent UDF and Scheme Programming | 0 | November 7, 2015 09:19 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 05:22 |
Appropiate turbulence model for natural convection | Diego Peinado | FLUENT | 0 | August 10, 2005 08:24 |
Approximate Mixing due to Natural Convection | Greg Perkins | Main CFD Forum | 0 | February 12, 2003 19:43 |
