Airfoil - Critical Reynold?
Old   October 1, 2016, 17:35
Default Airfoil - Critical Reynold?
William
Wingman is on a distinguished road
I am trying to choose the most appropriate model for my airfoil / wing. The chord length is approximately 0.165m and my maximum velocity of 15 m/s. I'm using density of 1.225 kg/m3 and dynamic viscosity of 0.000018375 kg/ms.
Using Re = (rho*V*L)/(mu) = (1.225*15*0.165)/(0.000018375)
gives me Reynolds number of 165.000.
What is the Critical Reynolds number for Airfoils? Is there some rule of thumb for this? I'm leaning towards a Turbulent model... k-omega SST?
The wing I'm using has different shape than most NACA profiles and has a blunt edge.
Wingman is offline   Reply With Quote
Old   October 3, 2016, 18:21
Matt
fluid23 is on a distinguished road
Are you asking what Reynolds number boundary layer transition occurs?
fluid23 is offline   Reply With Quote
Old   October 4, 2016, 19:04
truffaldino's Avatar
truffaldino is on a distinguished road
You will be wasting your tme with k-omega and any other turbulence modelling at such a low reynolds number. Use x-foil or xflr5: if there is no massive separation/bubbles, then your results will be much more accurate and you will easily and quickly see if there is separation, transition, where it happens etc.
truffaldino is offline   Reply With Quote
airfoil, reynolds number, wing
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
