What's the highest turbine inlet temperature in the modern gas turbine blade ? |
September 27, 2016, 07:42 |
Rep Power: 10 |
Hello guys,
Please, who can tell me how much the highest turbine inlet temperature (combustion chamber exit temperature) that can be reached in the modern gas turbine. Thanks. |
September 27, 2016, 13:12 |
mehak
Rep Power: 10 |
1600 to 1700 in can type combustion chamber
September 28, 2016, 04:25 |
Rep Power: 10 |
1700 C° ? Thank you for your answer
October 7, 2016, 06:10 |
Rep Power: 10 |
Modern gas turbines can reach up to 1200 to 1400 C, however some has reached up to 1600 C. That is the highest I know of and it is manufactured and working in a plant in Japan.
October 9, 2016, 15:01 |
Robert
Rep Power: 17 |
Modern F class IGTs usually have a TIT of around 1450C
G/H Class in the 1520-1550C range. MHI have a J(?) class running but I'm not sure if it is really a released engine yet. I would imagine aero, especially military, engines can get hotter at least for periods of operation. |
film cooling, gas turbine blade, heat transfer |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
blade analysis of gas turbine | Fayyaz Husain | Main CFD Forum | 1 | March 3, 2010 02:13 |
force acting on gas turbine blade.... | vvj | Main CFD Forum | 1 | March 3, 2010 02:04 |
FEA of gas turbine blade and disc | sureee | Main CFD Forum | 3 | March 15, 2006 05:59 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
