Absorption coefficient of air
Old   September 12, 2016, 17:16
Default Absorption coefficient of air
Bhupesh
bhups45 is on a distinguished road
Hi all,
I am quite new to radiation simulation and I am using ANSYS for my problem.
My question is about the absorption coefficient Rosseland approximation.
I am doing a simulation for heating glass with air in a room. While using the rosseland or DO approximation for radiation, as I have seen in some of other threads that they say to use a very small value of absorption coefficient of air, but if we see the rosseland approximation for radiative conductivity, this will result in a very high value for the same, which would mean that the heat conductivity of air is very high, which is not correct physically. So, I have 2 questions here:
1) Can the absorption coefficient be greater than 1?
2) What I think is that the absorption coefficient of air should have a very high value, such that the rosseland approximation gives small value of thermal conductivity, is this correct?
NOTE: I know I should use the DO model for semi-transparent material, but here I am more concerned about the absorption coefficient of air as it can't be taken as zero.
Thanks in advance!!
bhups45 is offline   Reply With Quote
Old   September 12, 2016, 19:05
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
It might be that you are confusing the terms "thermal conductivity" and "radiative thermal conductivity". While air as a gas has a rather low thermal conductivity, its radiative thermal conductivity is indeed rather high.
Absorption coefficients can not be greater than 1. This would be in conflict with thermodynamics.
flotus1 is offline   Reply With Quote
Old   September 13, 2016, 03:32
Bhupesh
Thanks for your reply!
I am also a bit confused about "Absorbance" and "Absorption coefficient". I can understand that Absorbance cannot be greater than 1, but I am unable to understand why this should be true for Absorption Coefficient.
Also, if the radiative thermal conductivity of air is high, then taking into account Rosseland model, the total thermal conductivity of air will be very high which doesn't seem to give correct result as in my simulation, the whole room is heated up to very high temperature in a few second if I use very small value of absorption coefficient of air.
Thanks in advance!
Old   September 13, 2016, 09:40
flotus1's Avatar
Alex
I am not too familiar with this model. How does the radiative absorption coefficient alter the thermal conductivity? Formula? Link to the manual of the software you are using?
Old   September 13, 2016, 10:13
Bhupesh
I am using ANSYS Fluent for my simulation.
The formula and description of model (Rosseland) can be found here:
http://www.afs.enea.it/project/neptu...th/node113.htm
The definition of term \Gamma can be found here:
http://www.afs.enea.it/project/neptu...th/node112.htm
Old   September 13, 2016, 12:11
flotus1's Avatar
Alex
While the model apparently uses conductive heat transfer as an analogy to model radiative heat transfer, it clearly distinguishes between radiative and conductive heat flux and radiative conductivity and thermal conductivity respectively.
Please ignore what I said about the absorption coefficient, I got the terms mixed up myself.
Maybe somebody else can help.
Old   September 13, 2016, 20:42
Bhupesh
@flotus1, thanks for your time..
absorption coefficient, radiation, rosseland
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
opaque surface absorption coefficient amrjoao FLUENT 0 August 24, 2011 12:27
Absorption coefficient > 1 ? Jamiro FLUENT 3 June 8, 2001 11:55
