September 10, 2016, 11:50 |
Flow over backward-facing step
Amirhossein Taran
Rep Power: 10 |
Hello guys
i've been simulated Flow and Heat transfer over backward facing steps using fortran . i want to wrote a paper of it and i want to to ask you guys how? note : if you had any idea that made this research better please tell me . thanks . |
September 10, 2016, 11:55 |
Filippo Maria Denaro
Rep Power: 73 |
The BFS flow has been extensively investigated both experimentally and numerically...It is a standard test case for new developed code.
High Re number turbulent flows have been collected in database. I don't suggest to think a paper focusing on the feature of the flow. If you have a new numerical methodology or a new turbulence model to assess, use it and compare your results to the existing data base |
September 10, 2016, 13:53 |
spl
Rep Power: 11 |
Further to FMDenaro comment there's also current research on active flow control on the backward facing step geometry, such as pulsating jets for wake reduction.
September 12, 2016, 16:13 |
Amirhossein Taran
Rep Power: 10 |
thanks all you guys .
backward facing steps, cfd code, fortran code |
Wrong calculation of y+ in flow over backward facing step | hedi-72 | OpenFOAM Post-Processing | 0 | January 26, 2016 11:02 |
help with supersonic flow over duct with backward step | quiqui | FLUENT | 1 | May 9, 2013 11:13 |
air-fuel mixing in backward facing step | abdullahkarimi | Main CFD Forum | 0 | March 19, 2011 18:39 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Turbulent flow over a backward facing step | Jenner | Main CFD Forum | 1 | December 2, 2006 11:21 |
