Numerical treatment of the source term in combustion equations |
September 7, 2016, 17:37 |
#21 | |
Tobias Holzmann
Rep Power: 52 |
Hi all,
well I want to split the calculation into: a) Calculate the source terms omega and update the Y values b) Solve the transport equation At the moment I am only interested in the steady-state solution (no transient). for a) I would do the following: [LaTeX Error: Syntax error] Solving that stiff system with the BDF like: Here I update the "old" values with the BDF method and then I solve the transport equation (simple one). Of course the above equation has to be looped till I get steady-state here. Quote:
Keep foaming, Tobias Holzmann |
September 7, 2016, 17:47 |
#22 |
Filippo Maria Denaro
Rep Power: 73 |
Actually, if you consider the splitting and you adopt an implicit method, you have to consider that, say Y* the intermediate field, the equation writes as
Y*- dt S(Y*)=Y^n-1 |
September 7, 2016, 20:43 |
#23 | |
Michael Prinkey
Rep Power: 25 |
https://en.wikipedia.org/wiki/Linear_multistep_method ABM schemes use the RHS value at two or more different time levels, rather than using multiple old time values of the solution. They generally work better than high-order backward differencing. If you are a building a split implicit/explict scheme, Trapzoidal Rule (2nd-order Adams Moulton) for the implicit terms and 2nd-order Adams Bashforth for explicit terms often work well. |
September 8, 2016, 04:13 |
#24 | ||
Tobias Holzmann
Rep Power: 52 |
September 8, 2016, 05:16 |
#25 |
Rep Power: 73 |
Actually, you cannot get higher order accuracy even using AB methods, the reason being in the splitting. Immagine you work first without splitting. Integrating in time you get
Y^n+1-Y^n = Int[tn+1;tn] ( D d2 Y/dx^2 + S(Y)) dt Now, with the splitting you solve Y*-Y^n = Int[tn+1;tn] S(Y*) dt Y**-Y* = Int[[tn+1;tn] ( D d2 Y**/dx^2) dt Therefore, the best you can get (but with some care), is only second order accuracy in time. |
September 8, 2016, 07:16 |
#26 |
Still, unless there is some specificity regarding chemical source terms, as he intend to just reach the steady state, i guess such effort on the time acuracy is not actually worth it. He jest needs to keep it stable and consistent, not time accurate.
September 8, 2016, 07:28 |
#27 |
Rep Power: 73 |
That's true Paolo, however at the steady state only the time derivatives in the truncation error vanish. I am not sure If the remaining spatial derivatives retain some time step multiplication so that the temporal accuracy enters into the global accuracy.
But I agree, I wouldn' take too care of time accuracy in a first stage of a steady solution. |
September 8, 2016, 07:34 |
#28 | |
September 8, 2016, 07:45 |
#29 | ||
Tobias Holzmann
Rep Power: 52 |
Dear all,
If you are interested, I will keep you up to date with the latest results. Unfortunately I will not find time the next 4 days ...
September 12, 2016, 17:10 |
#30 |
Tobias Holzmann
Rep Power: 52 |
Dear all,
it would be very helpful to get some feedback about section 1.2.2 in the attachment. The PDF is just a draft so nothing is finished http://holzmann-cfd.de/forumCases/UserGuide.pdf
Keep foaming, Tobias Holzmann Last edited by Tobi; September 12, 2016 at 17:32. Reason: Corrected section 1.5 to 1.2.2 |
September 12, 2016, 17:19 |
#31 | |
Rep Power: 73 |
September 12, 2016, 22:41 |
#33 |
Arjun
Rep Power: 34 |
Tobias
What is the size of system we are talking here. Does it depend on number of species we are talking about. So if you took the coupled system then does the system is of size Nspecies x Nspecies. If thats the case can't you use direct solver on coupled system, you can use some multifrontal solver. I believe some open libraries are there that provide it. |
September 12, 2016, 23:59 |
#34 |
Michael Prinkey
Rep Power: 25 |
I don't completely understand your flamelet formulation, but I grasp the essential ideas you are working towards. I am a bit concerned that you are choosing a timestep for the X updates and then iterating to convergence while picking a different timestep for your Y updates. This *may* be OK in the limit of large time, but my gut tells me that it does not preserve the relative time scales of the reaction and the transport terms. This convergence loop seems like it should essentially just give you equilibrium chemistry results at every timestep. I think I can follow your recipe and choose the two different timesteps independently and generate very different physical results and, of course, that indicates that the scheme in inconsistent.. Again, I haven't proved or tested this, but I see it as a potential problem.
Stiff (split) chemistry solvers usually assume a transport time step (DT) based on CFL or some other criteria. Then, reaction timesteps (dt) are chosen to evolve the system from t_0 to (t_0 + DT). Usually, dt << DT. But, you step forward the reactions to t_0 + DT, and then you evolve the transport fractional step to t_0 + DT. This retains consistency between the transport and the reaction timescales automatically and gives time accurate results. This will, of course, provide consistent steady state results as well as you take t->inf. But choosing different timesteps changes the effective timescale of each--techniques exist to precondition pseudo-timestepping schemes that discard time accuracy to get faster convergence, but those techniques are complicated and maintain the relative scale of the terms as time goes to infinity. |
September 13, 2016, 03:04 |
#35 | ||||
Tobias Holzmann
Rep Power: 52 |
the number of systems depend on two things. First the space discretization (mixture fraction) depend on the number of points we want to have. Lets say 100 and within one discrete point, the chemical source term depend on the number of species that are included within the detailed chemistry. The Jacobian is a nSpecies x nSpecies matrix. The fact that I do not want to use some open libraries are as follow: I want to make my hands dirty to understand things in more details I know that it is somehow stupid to re-invent the tire but for a good understanding, it is necessary for me (I am not a genius - unfortunately) Quote:
Note that till now I am not solving the temperature equation. I hope to find time to add this to the figure in section 1.2.2 today evening. Thanks for your replays.
September 13, 2016, 16:08 |
#36 |
Tobias Holzmann
Rep Power: 52 |
I made changes to the calculation procedure. I really appreciate your opinions. Thanks in advance. The file is updated and is the same as before, or just »click«
March 20, 2017, 09:58 |
#37 | |
Arjun
Rep Power: 34 |
The current version uses VODE based species stiff ode integration and I use operator spliting method that fluent and starccm typically offer. StarCCM also offers something called Chemistry ADI (This is what i believe they call it) that can handle even larger time steps. I am not looking at it at the moment but in future if i am unhappy with operator splitting i might visit it. Next week or so I try to validate the solver with various sets up and see how robust it is. So far looks good but it has not done any challenging thing too. Last edited by arjun; March 20, 2017 at 11:47. |
September 15, 2020, 14:42 |
#38 |
Reviewer #2
Rep Power: 11 |
Hi All,
I am creating a simple solver that involve transport and reaction. Different from Tobi's purpose, I would like to get the time accurate solution. I think this post is relevant and also extended from the original discussion. Here is what I have done so far. I would like to hear your valuable advices to improve the solver's efficiency since I am really interested in simulate the transport and reaction for a large timescale ~ hr to day. 1. First I solve the reaction term dY/dt = f(Y) only with the ODE solver in OpenFOAM from t0 to t0+Dt with Dt being the time step size of the transport equation. Y0 and YEnd is the initial and final results at t0 and t0+Dt in this ODE. The ODE time step size (dt) that is automatically determined by the ODE solver of OpenFOAM so that sufficiently small to meet the error tolerance. 2. Second I construct the source term as dYdt = (YEnd-Y0)/Dt. 3. Third shuffle the dYdt as an explicit source term to the transport equation and solve the transport equation. Here are my questions: I would like to take the time step (Dt) as large as possible. But I observe that the transient solution has depends on the time step size in the transport solver (Dt). The solution changes even I reduce the time step size to 1e-2, which is very challenge to the intended simulation length (hr to day). What is the bottleneck of the code? I guess this way to split the equation is only first order accurate. Will Strang splitting help? Without too much of work, Strang splitting can be implemented with the first order time integration scheme for the transport equation. Based on the exsiting first order splitting, I can use second order scheme for the transport equation. If one choose the accuracy between splitting and transport, which one' accuracy should be prioritized? How can I estimate the time scale of the reaction? Thanks in advance, Rdf Last edited by randolph; September 15, 2020 at 16:35. |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 16:14 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
